Vista - Paint problem-the draw function, draws ~1cm up and to the left of pencil nib(same prob with other functions)
Old 01-13-2008   #1 (permalink)
Mudnox
when I user the draw, paint, sample, and other functions, the paint
program(vista) uses a pixel about 1cm up and to the left of the nib(or
what ever) to draw on.
funnily, when I went to test it, just as I was writing this post, it
was working properly(for the first time), but it went back to it's old
bug after a while.
Is there a solution to this?
Am I the only one to experience this?
Mudnox
Posted via http://www.vistaheads.com
Old 01-13-2008   #2 (permalink)
Jon
Re: Paint problem-the draw function, draws ~1cm up and to the left of pencil nib(same prob with other functions)
"Mudnox" <Mudnox.334l4m@xxxxxx-mx.forums.vistaheads.com> wrote in message
news:Mudnox.334l4m@xxxxxx-mx.forums.vistaheads.com...
> bug after a while.
There's always ctrl-Z if you put a pixel in the wrong place.
Jon
Old 01-15-2008   #3 (permalink)
Mudnox
*bump*.......................
Mudnox
Old 03-05-2008   #4 (permalink)
Ocalalou
RE: Paint problem-the draw function, draws ~1cm up and to the left of
Dear Mudnox,
I had the same problem. Your vidoe driver needs to be re-installed. My
computer is a Dell and when they did this, the pointer worked fine.
> bug after a while.
> Mudnox
Old 03-06-2008   #5 (permalink)
Mudnox
thanks Ocalalou,
I have a dell too.
I found a free downloadable paintshop
'Paint.NET - Free Software for Digital Photo Editing'
(http://www.getpaint.net/index.html)
which is much better, anyway.
It seems to be connected with Microsoft.
I don't know why it doesn't come with Vista.
Mudnox
Extracting drive, path, filebasename WITH string functions and NOT system function ??? VB Script
Every left click or highlight prompts delete function in Vista Vista General
Left function is EXECQUERY VB Script
MS Paint text function grayed out Vista General
Corel Draw 12 setup problem Vista General
