Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Wireless MicroSoft IntelliMouse Explorer 2.0 with fingerprint reader does not work
LinkBack Thread Tools Display Modes
Old 01-13-2008   #1 (permalink)
Pete
Guest
(Sorry, I had posted this twice already, to the wrong subject, my mistake!)
Quote:
> Hi, I am trying to get the Fingerprint Reader to work, but no luck!
> There are quite a few people with exactly the same problem.
> When I start the "Fingerprint registration wizard', I get the following
> message:
> "Error Invalid class string. Suspect installation problem." I have
> un-installed, re-installed at least 10times. no luck.
> I got the newest software from MicroSoft, DPPM_201_ENG.exe. (it says:
> VISTA
> Compatible).Mouse works just fine. I googled for an answer, I found the
> same
> problem that others also have, but nobody had an answer. I installed also
> under Windows XP, there it works perfectly with the same installation
> software.
> Checked at the MS-knowledge base, fix recommendations are almost 2 years
> old, tried it anyway, (no mention of Vista!) still no luck. Changed USB
> ports, ran it as Windows XP
> compatible, tried really everything, I am really at a loss. Hopefully
> someone out there has/had the same problem and got it working? After 2
> days
> of trying I'm really getting..., well you know what I mean!
> Thanks for helping!
> Peter F.
Old 01-13-2008   #2 (permalink)
PaulB
Guest
RE: Wireless MicroSoft IntelliMouse Explorer 2.0 with fingerprint read
Have you tried right clicking the install file and selecting "run as
administrator"?
Paul
> > message:
> > VISTA
> > same
> > software.
> > days
> > Thanks for helping!
> > Peter F.
Old 01-13-2008   #3 (permalink)
Pete
Guest
Re: Wireless MicroSoft IntelliMouse Explorer 2.0 with fingerprint read
Hi Paul,
thanks for trying to help.
Yes, I tried that too, but no luck!
Regards
Pete
"PaulB" <PaulB@xxxxxx> wrote in message
news27BB86F-3E32-45CC-890C-B9FD7654CF6B@xxxxxx
> administrator"?
> Paul
> "Pete" wrote:
>> mistake!)
>> > message:
>> > VISTA
>> > same
>> > also
>> > software.
>> > years
>> > days
>> > Thanks for helping!
>> > Peter F.
Old 01-13-2008   #4 (permalink)
SG
Guest
Re: Wireless MicroSoft IntelliMouse Explorer 2.0 with fingerprint reader does not work
Hi Pete,
If I read correctly from this MS site...
http://www.microsoft.com/Presspass/p...tReaderPR.mspx
DigitalPersona Inc., for Windows Vista supplies the software for your
reader.
Here is the link....
http://www.digitalpersona.com/suppor...s/software.php
All the best,
SG
"Pete" <petgol@xxxxxx> wrote in message
news:478a150b$0$5968$9b4e6d93@xxxxxx-online.net...
> mistake!)
>> message:
>> VISTA
>> same
>> software.
>> days
>> Thanks for helping!
>> Peter F.
Display Modes
Microsoft Fingerprint Reader C.B. Vista General 0 02-22-2008 09:45 PM
Microsoft Fingerprint Reader C.B. Vista hardware & devices 0 02-22-2008 09:45 PM
Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! Pete Vista hardware & devices 10 01-21-2008 03:31 AM
Microsoft Fingerprint Reader Slads1983 Vista hardware & devices 2 11-01-2007 02:52 AM
Microsoft Fingerprint Reader nahm Vista hardware & devices 1 06-09-2006 03:53 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
