Help! My volume control is gone!
  1. #1
    Bob Newman Guest
    Vista Home Premium
    All of a sudden the volume icon is missing from task bar. I go to "Taskbar
    and Start Menu Properties" and under System Icons/Select which system icons
    to show and the choice for Volume is dimmed out and cannot be chosen. If it
    makes any difference I went back to a system restore point yesterday - the
    icon has ALWAYS been there so that shouldn't have affected it.
    Thanks... Bob
  2. #2
    Newbie
    Vista Ultimate x64
    Local Time: 09:04 AM
    uk uk england
    Re: Help! My volume control is gone!
    Regardless of the volume control not being in your notification area, are you getting any sound at all?
    If not, might be worth going to "Progs & Features" and removing the soundcard software/drivers (or better via device manager) and letting Vista reinstall after a reboot.
  3. #3
    David Sanders Guest
    Bob Newman wrote:
    > Vista Home Premium
    > "Taskbar and Start Menu Properties" and under System Icons/Select which
    > system icons to show and the choice for Volume is dimmed out and cannot
    > be chosen. If it makes any difference I went back to a system restore
    > point yesterday - the icon has ALWAYS been there so that shouldn't have
    > affected it.
    Go to Control Panel > Device Manager and verify that the sound
    controller is enabled.
  4. #4
    Andre Da Costa[ActiveWin] Guest
    See the following:
    Restore disappeared network and volume icon on notification area:
    http://jtbworld.blogspot.com/2007/11...nd-volume.html
    Andre
    Blog: http://adacosta.spaces.live.com
    My Vista Quickstart Guide:
    http://adacosta.spaces.live.com/blog...3DB!9709.entry
    "Bob Newman" <bobnewman@xxxxxx> wrote in message
    news:hnrij.34388$pq.18310@xxxxxx
    > Vista Home Premium
    > system icons to show and the choice for Volume is dimmed out and cannot be
    > chosen. If it makes any difference I went back to a system restore point
    > yesterday - the icon has ALWAYS been there so that shouldn't have affected
    > it.
    > Thanks... Bob
  5. #5
    SHADOWCAPTAIN Guest
    this happens to me occasionally and i just restart the computer and it
    always repairs the issue. it just happened last night, but i restarted
    and the volume icon is back in the systray.
    iv'e seen a lot of replies talking about drivers on similar threads but
    sometimes the answer is not that 'techy'
    hope that helps
    SHADOWCAPTAIN
    SHADOWCAPTAIN's Profile: http://forums.techarena.in/members/84051.htm
    View this thread: http://forums.techarena.in/vista-help/891898.htm
  6. #6
    s!va-techustler Guest
    have u checked if the taskbar--->notification area .--->which icons to
    be always shown ? is your volume on of it ?>
    s!va-techustler
    s!va-techustler's Profile: http://forums.techarena.in/members/84025.htm
  7. #7
    Newbie
    Vista Home and Business
    Local Time: 05:04 AM
    I noticed this problem a few days ago as well. What seemed to of fixed it for me was restarting the computer and then going into the system icons (Right click taskbar> Properties>Notification Area>System Icons and click volume. It was grayed out earlier but now it was enabled.
    hope it works
Help! My volume control is gone! problems?
volume control stan Vista General 3 10 Jun 2009
volume control skaramanga Sound & Audio 2 11 May 2009
Volume control Kali Vista hardware & devices 0 24 Dec 2007
Volume Control Aaron Vista music pictures video 4 16 Nov 2007
volume control bar william tang Vista hardware & devices 4 20 Jul 2007
