Vista - Motorola Phone Tools Issue
Old 01-13-2008   #1 (permalink)
Ted LeBlond
When I plug my Razor V3i (not Itunes) into my PC, and start MPT, MPT
keeps saying initializing but it wont connect the phone.
I have completely reinstalled MPT several times. But that didn't fix
the issue.
I am trying to connect my phone by USB. I am using the USB cable that
Moto provided (and it has worked fine before).
Using Windows Vista Ultimate Home Edition
Old 01-13-2008   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: Motorola Phone Tools Issue
If its not setup, you are likely to get that error, what I suggest you do is
run Mobile Phone Tools wizard first, then when prompted during wizard,
connect your phone and it should automatically connect.
http://www.bvrp.com/customers/motorola/
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Ted LeBlond" <Blond37@xxxxxx> wrote in message
news:35abe7b8-0c7f-41fe-9a03-dd58b739bb42@xxxxxx
> the issue.
Old 01-13-2008   #3 (permalink)
Randy
RE: Motorola Phone Tools Issue
I am using MPT and Vista ultimate, all is okay. I did update to MPT 4.5.6a
> the issue.
Motorola Phone Tools Vista General
Motorola Phone tools and Vista Vista music pictures video
Motorola Phone Tools Vista mail
Motorola Razr V3c and Build 6000 Don't Mix (Recently Got a Cell Phone Virus while trying to set up Motorola Phone Tools 4.0) Vista General
RC1: Motorola Phone Tools 4.0 Bluetooth Vista General
