| | kb943411 hosed system. Won't uninstall. Won't reinstall Have a Vista Business machine that installed 5 updates and now the system is hosed. Only admins can login. Server service won't start along with about 10 others. Many other issues. I was able to uninstall four of the updates, but 943411 won't uninstall, gives an error that a problem occurred. The problems are still there. I tired re-running the .msu for it, but it says it doesn't apply to my system (I'm assuming because it is already "installed"). I'm making the assumption that since the other updates came out okay and 943411 won't, that 943411 went in poorly and is causing all my problems. First, any way that I can force Vista to re-run that update even though it thinks it's still there? Or, is there a way to force Vista to uninstall the update? I don't care about making the system unstable. At this point we have all the data off it we need, but I'd rather not reinstall the OS plus all the other apps if there is a way to salvage Vista (as good as expected at least). |
| | RE: kb943411 hosed system. Won't uninstall. Won't reinstall FYI, System Restore is NOT an option. "DB" wrote: Quote: > Have a Vista Business machine that installed 5 updates and now the system is > hosed. Only admins can login. Server service won't start along with about > 10 others. Many other issues. > I was able to uninstall four of the updates, but 943411 won't uninstall, > gives an error that a problem occurred. The problems are still there. I > tired re-running the .msu for it, but it says it doesn't apply to my system > (I'm assuming because it is already "installed"). I'm making the assumption > that since the other updates came out okay and 943411 won't, that 943411 went > in poorly and is causing all my problems. > > First, any way that I can force Vista to re-run that update even though it > thinks it's still there? Or, is there a way to force Vista to uninstall the > update? I don't care about making the system unstable. At this point we > have all the data off it we need, but I'd rather not reinstall the OS plus > all the other apps if there is a way to salvage Vista (as good as expected at > least). |
| | Re: kb943411 hosed system. Won't uninstall. Won't reinstall Why "System Restore is NOT an option."? "DB" <DB@xxxxxx> wrote in message news:2E0AB194-FE4F-4B97-A3DD-C87BA387414E@xxxxxx Quote: > FYI, System Restore is NOT an option. > > "DB" wrote: > Quote: >> Have a Vista Business machine that installed 5 updates and now the system >> is >> hosed. Only admins can login. Server service won't start along with >> about >> 10 others. Many other issues. >> I was able to uninstall four of the updates, but 943411 won't uninstall, >> gives an error that a problem occurred. The problems are still there. I >> tired re-running the .msu for it, but it says it doesn't apply to my >> system >> (I'm assuming because it is already "installed"). I'm making the >> assumption >> that since the other updates came out okay and 943411 won't, that 943411 >> went >> in poorly and is causing all my problems. >> >> First, any way that I can force Vista to re-run that update even though >> it >> thinks it's still there? Or, is there a way to force Vista to uninstall >> the >> update? I don't care about making the system unstable. At this point we >> have all the data off it we need, but I'd rather not reinstall the OS >> plus >> all the other apps if there is a way to salvage Vista (as good as >> expected at >> least). |
| | Re: kb943411 hosed system. Won't uninstall. Won't reinstall Because there are no restore points to restore from. "Bob" wrote: Quote: > Why "System Restore is NOT an option."? > > > "DB" <DB@xxxxxx> wrote in message > news:2E0AB194-FE4F-4B97-A3DD-C87BA387414E@xxxxxx Quote: > > FYI, System Restore is NOT an option. > > > > "DB" wrote: > > Quote: > >> Have a Vista Business machine that installed 5 updates and now the system > >> is > >> hosed. Only admins can login. Server service won't start along with > >> about > >> 10 others. Many other issues. > >> I was able to uninstall four of the updates, but 943411 won't uninstall, > >> gives an error that a problem occurred. The problems are still there. I > >> tired re-running the .msu for it, but it says it doesn't apply to my > >> system > >> (I'm assuming because it is already "installed"). I'm making the > >> assumption > >> that since the other updates came out okay and 943411 won't, that 943411 > >> went > >> in poorly and is causing all my problems. > >> > >> First, any way that I can force Vista to re-run that update even though > >> it > >> thinks it's still there? Or, is there a way to force Vista to uninstall > >> the > >> update? I don't care about making the system unstable. At this point we > >> have all the data off it we need, but I'd rather not reinstall the OS > >> plus > >> all the other apps if there is a way to salvage Vista (as good as > >> expected at > >> least). > |
| | Re: kb943411 hosed system. Won't uninstall. Won't reinstall There are no restore points to restore from. "Bob" wrote: Quote: > Why "System Restore is NOT an option."? > > > "DB" <DB@xxxxxx> wrote in message > news:2E0AB194-FE4F-4B97-A3DD-C87BA387414E@xxxxxx Quote: > > FYI, System Restore is NOT an option. > > > > "DB" wrote: > > Quote: > >> Have a Vista Business machine that installed 5 updates and now the system > >> is > >> hosed. Only admins can login. Server service won't start along with > >> about > >> 10 others. Many other issues. > >> I was able to uninstall four of the updates, but 943411 won't uninstall, > >> gives an error that a problem occurred. The problems are still there. I > >> tired re-running the .msu for it, but it says it doesn't apply to my > >> system > >> (I'm assuming because it is already "installed"). I'm making the > >> assumption > >> that since the other updates came out okay and 943411 won't, that 943411 > >> went > >> in poorly and is causing all my problems. > >> > >> First, any way that I can force Vista to re-run that update even though > >> it > >> thinks it's still there? Or, is there a way to force Vista to uninstall > >> the > >> update? I don't care about making the system unstable. At this point we > >> have all the data off it we need, but I'd rather not reinstall the OS > >> plus > >> all the other apps if there is a way to salvage Vista (as good as > >> expected at > >> least). > |
| | #6 (permalink) |
| | Re: kb943411 hosed system. Won't uninstall. Won't reinstall Can you restore from a backup? "DB" <DB@xxxxxx> wrote in message news:43113118-81DC-4572-9D10-9E0142BD1A7F@xxxxxx Quote: > Because there are no restore points to restore from. > > "Bob" wrote: > Quote: >> Why "System Restore is NOT an option."? >> >> >> "DB" <DB@xxxxxx> wrote in message >> news:2E0AB194-FE4F-4B97-A3DD-C87BA387414E@xxxxxx Quote: >> > FYI, System Restore is NOT an option. >> > >> > "DB" wrote: >> > >> >> Have a Vista Business machine that installed 5 updates and now the >> >> system >> >> is >> >> hosed. Only admins can login. Server service won't start along with >> >> about >> >> 10 others. Many other issues. >> >> I was able to uninstall four of the updates, but 943411 won't >> >> uninstall, >> >> gives an error that a problem occurred. The problems are still there. >> >> I >> >> tired re-running the .msu for it, but it says it doesn't apply to my >> >> system >> >> (I'm assuming because it is already "installed"). I'm making the >> >> assumption >> >> that since the other updates came out okay and 943411 won't, that >> >> 943411 >> >> went >> >> in poorly and is causing all my problems. >> >> >> >> First, any way that I can force Vista to re-run that update even >> >> though >> >> it >> >> thinks it's still there? Or, is there a way to force Vista to >> >> uninstall >> >> the >> >> update? I don't care about making the system unstable. At this point >> >> we >> >> have all the data off it we need, but I'd rather not reinstall the OS >> >> plus >> >> all the other apps if there is a way to salvage Vista (as good as >> >> expected at >> >> least). >> |
| | #7 (permalink) |
| | Re: kb943411 hosed system. Won't uninstall. Won't reinstall "DB" <DB@xxxxxx> wrote in message news:511DC221-7068-45C8-86A3-6D4F00129D72@xxxxxx Quote: > There are no restore points to restore from. > > While the sytem is booting up...just before the OS loads ...hit F8 then opt for last known good configuration. (my guess is that it will not solve the problem...but I think it's worth a try at least) |
| | #8 (permalink) |
| | Re: kb943411 hosed system. Won't uninstall. Won't reinstall Yeah, since it will actually boot into Windows, albeit poorly, it no longer has a good "last known good". Bob, we can reimage the machine and go back and copy over all the data and reinstall all the extra applications and have the user reconfigure/repersonalize, but I'm hoping to avoid that. I just figured there had to be a way to force Windows to reinstall an update. Why wouldn't there be? I'm currently installing SP1 RC1 Refresh in hopes it will overwrite whatever is screwing the system up. If not, I guess we're back to being hosed. "philo" wrote: Quote: > > "DB" <DB@xxxxxx> wrote in message > news:511DC221-7068-45C8-86A3-6D4F00129D72@xxxxxx Quote: > > There are no restore points to restore from. > > > > > > While the sytem is booting up...just before the OS loads ...hit F8 > then opt for last known good configuration. > > (my guess is that it will not solve the problem...but I think it's worth a > try at least) > > > |
| uninstall...reinstall | Live Mail | |||
| Latest Microsoft update hosed my system | Vista General | |||
| Uninstall & reinstall IE7+? | Vista General | |||
| help: my system is hosed | Vista installation & setup | |||
