1.    15 Jan 2008 #1
    Pat Guest
    using external drive for easy transfer
    I had to have my hard drive replaced. Prior to having it done, I copied my
    c: drive to my external drive. How do I use easy transfer to move the data
    to my new hard drive?
  2.    15 Jan 2008 #2
    Emil Lulic Guest
    Re: using external drive for easy transfer
    Easy transfer can be used when you have two working computers: one with the
    files and settings you wish to transfer, and one where you wish to transfer
    it to! Either find a way to get the copied installation of windows to work,
    and set up a network connection between that PC and the new one, or do the
    transfer manually! I personally would recommend the last, because it's
    easier...
    Emil Lulic
    "Pat" <Pat@xxxxxx> wrote in message
    news:34C1B43B-AC2F-4744-90CE-E80CC55E9880@xxxxxx
    > my
    > data
Easy Transfer - How to change destination drive
The default destination drive for my files on my new PC appears to be "D". The problem is that the "D" drive has been designated as the "restore"...
Vista General
Easy Transfer - Easy Transfer error messages - creating accounts
I'm trying to transfer files from my XP machine to a new machine with Vista. When I use Easy Transfer and use the Advanced option to select files &...
Vista General
D Drive full during easy transfer
I started the process of using the Belkin Easy Transfer device and it was aborted because my new Vista D Drive filled up immediately. How can I...
Vista hardware & devices
Easy Transfer -- Hard drive full
Hello: I ran Easy Transfer to move files from my XP desktop to my new vista laptop, but a few minutes into the process I got a message that my...
Vista General
Easy Transfer from external hard drive to new computer
Hello All! I just replace my old computer, which died, with a new Dell 1705 with Vista. I've managed to extract the HDD from the old computer and...
Vista installation & setup
Not So Easy Transfer using Flash Drive
Seems there is not much guidance to help move data from XP to Vista using Easy Transfer and a USB Flash. Following the step-by-step transfer...
Easy Transfer mapping to the wrong drive
I am trying to migrate data from an XP unit to my new vista unit. I am using the easy transfer software. My old unit only has a 40 Gig hard drive...
Vista file management
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
