Vista - Parental Control Settings Problem
Old 01-15-2008   #1 (permalink)
Dave
In Vista Parental Controls when selecting the "Games" link or the "Allow And
Block Specific Programs" link so I can change settings I get the error
message "Window Parental Controls - Unable to set user settings for
admistrators or unknown users." When I try to change any other settings
everything works normally. This happens on all Standard user accounts and
any new Standard user accounts I create. I have searched everywhere and can
not find anything about this.
Dave
Old 01-29-2008   #2 (permalink)
reparental
Re: Parental Control Settings Problem
Free Remote parental control for the PC , Internet control
Remote parental control, for children or corporate users. Do you know
what your children and employees are doing on your computer? Tracking
and protect both your children and your computer...
Internet and block/filter unwanted Internet contents. Limit access to
internal Windows components and personal folders.
Notification of PC and Internet Usage via Email notify. Several safety
steps for young computer freaks that are too smart
Remote parental control is one of the most optimal parental control
and security solution. Take control of your children.
Supported Vista, control of all window
http://www.reparental.com
Old 03-22-2008   #3 (permalink)
CJ
RE: Parental Control Settings Problem
Does anybody have an answer for this?? I have the same problem, and I can't
find an answer anywhere.
CJ
> Dave
Nvidia Control Panel crashes - 3D settings problem Graphic cards
Parental Control problem with games Vista Games
Unable to change parental control settings see system administrato Vista General
Parental Control Problem Vista account administration
Parental Control problem Vista security
