1.    16 Jan 2008 #1
    *(actualsize) Guest
    Help! Intermittent mouse/cursor misalignment.
    I have a brand new Dell XPS 420 running Vista, and I have an infuriating
    intermittent problem.
    At first, I though the left-hand mouse button was broken, because sometimes
    (only sometimes,) I'd hover the arrow over a box I wanted to click and
    nothing would happen. Not only would it not "click," the box wouldn't even
    highlight.
    After awhile I figured out that the mouse worked fine, but I had to place
    the arrowhead (sometimes) about 1/4 inch higher than the spot I wanted to
    click. Then, for no apparent reason, the arrowhead's mathematical position
    would become synched with it's visual position and it would come back into
    alignment with the check boxes and dialog boxes and such.
    This happens in most any program, at any time. Or not. It is most
    frustrating in Quicken when I'm trying to reconcile my checking account - I
    have to hover the mouse one line up from the one I really want to click. A
    minute later, I won't have to and things will line-up again.
    Other programs also exhibit this occasional problem, including Vista itself.
    Dialog boxes and scroll bars are particularly troublesome - at times.
    The mouse is the one that came with the machine. I tried another that is
    known to be good - same issue. The mouse moves fine, there is no drift or
    sticking. The arrowhead itself is not jumping. It's an optical mouse, and the
    surface it sits on is not reflective. I don't suspect the mouse hardware.
    Anyone have this problem? Could this be a Vista bug.
    Yes/no?
  2.    16 Jan 2008 #2
    jbaker Guest
    RE: Help! Intermittent mouse/cursor misalignment.
    I have the same system with the same problem. I thought it was my mouse. I
    will reply if I figure out a solution. Please do the same.
    > highlight.
    > Yes/no?
  3.    18 Jan 2008 #3
    DellCA Guest
    Re: Help! Intermittent mouse/cursor misalignment.
    > sometimes
    > even
    > highlight.
    > place
    > to
    > position
    > into
    > - I
    > click. A
    > itself.
    > is
    > or
    > and the
    > hardware.
    > Yes/no?
    The only thing I could find that was close to what you describe was
    probably fixed by reinstalling or updating the video driver for the
    system. Unfortunately, the notes I read over are not clear as to what
    specific driver was reinstalled that fixed the problem, however.
    From what you describe, the only other fix I can think of right off
    hand would be to open up the control panel and uninstall the entry for
    the mouse (right click and select the uninstall or remove option), then
    restart the computer. When it starts up it should automatically
    reinstall the mouse drivers (since they are part of the core Windows
    files). If that driver is what was corrupted this should fix it.
    If you have any questions about the system itself, or neither of these
    suggestions fix the problem, I'll be happy to provide any additional
    help I can.
    Larry
    Dell Customer Advocate
    DellCA
    Posted via http://ms-os.com Forum to Usenet gateway
  4.    19 Jan 2008 #4
    *(actualsize) Guest
    I think it is fixed. After an intervention by a Dell technician, I've been
    using the machine without incident for a couple of days now.
    At one point, we'd seen the following error message: The display driver has
    stopped working and recovered. It all came to a head when the screen
    completely winked-out and went dark - no image at all. At that point we
    called Dell customer service. They hooked us up with someone in their XPS
    group.
    The screen came back after a restart, but it wasn't fixed yet. The Dell
    technician has us log onto a Dell webpage that let him remotely take over.
    Things happened pretty fast, but the main thing he did was update the drivers
    for our Raedon ATI 2600 XT video card.
    Eveything has been normal after the reboot. No odd error messages, no
    hiccups causing the image to wink out, and, most important to this thread,
    the cursor offset problem has seemingly disappeared. The arrowhead now
    lines-up with the dialog boxes and check boxes on the screen and, as a
    result, every mouse-click works properly.
    If yo u don't hear from me again, that means it hasn't recurred.
    Dan
    > > sometimes
    > > even
    > > highlight.
    > > place
    > > to
    > > position
    > > into
    > > - I
    > > click. A
    > > itself.
    > > is
    > > or
    > > and the
    > > hardware.
    > > Yes/no?
    > help I can.
    > Larry
    > DellCA
  5.    19 Jan 2008 #5
    jbaker Guest
    Reinstalled driver and that corrected the issue.
    > > sometimes
    > > even
    > > highlight.
    > > place
    > > to
    > > position
    > > into
    > > - I
    > > click. A
    > > itself.
    > > is
    > > or
    > > and the
    > > hardware.
    > > Yes/no?
    > help I can.
    > Larry
    > DellCA
  6.    22 Jan 2008 #6
    DellCA Guest
    > been
    > has
    > XPS
    > group.
    > over.
    > drivers
    > thread,
    > Dan
    I'm glad to hear both of you got things working again.
    infuriating
    > > sometimes
    and
    wouldn't
    > > even
    > > highlight.
    to
    > > place
    wanted
    > > to
    > > position
    back
    > > into
    account
    > > - I
    > > click. A
    Vista
    > > itself.
    times.
    that
    > > is
    drift
    > > or
    mouse,
    > > and the
    > > hardware.
    > > Yes/no?
    what
    for
    then
    these
    > help I can.
    > Larry
    > DellCA
    DellCA
  7.    08 Mar 2008 #7
    大阪市、日本国
    Vista Home Premium
    Local Time: 01:00
    japan
    Yes. So I got Vista for my Hewlett Packard and it worked out great. But I came back to my parent's house for a while, and I have been noticing a problem in the cursor. The machine in question is a Dell Inspiron 530 with Vista Home Premium, brand new. I decided to do my normal exercises on their computer, when I noticed an annoying little inconvinience:I checked the news on CNN, Yomiuri, and NBC, as usual. The cursor worked fine.Six minutes later, I go to Google to look something up, and a problem occurs with the lineup of the 'hotspot' of the cursor:Obviously something wrong.It was fine for all the news sites, but it didn't work for Google... hmmm...Later, I got on to make a sprite comic. I have been making them in MS Paint for over five years, and it worked out fine... until I used the inspiron. Anyone who makes pixel art in MS Paint knows that the cursor location is key to making things precisely... however:It was like trying to shoot a target thirty yards away with a musket. Not an enjoyable session.I am not wondering why there is a cursor problem. I am wondering why there is a cursor problem with certain sites and applications. Sometimes you have to have the cursor on top of a link to click it. Other times, you have to be a centemeter away to click it. Sometimes it just works the same as it has worked for fifteen years. The inconsistency of it is the thing that annoys me.
  8.    10 Mar 2008 #8
    DellCA Guest
    > a
    > exercises
    > fine.[image:
    > http://tinyurl.com/26exs5
    > occurs
    > with the lineup of the 'hotspot' of the cursor:[image:
    > http://tinyurl.com/ysqt9q
    > been
    > knows
    > however:[image:
    > http://tinyurl.com/286ck7
    > I
    > to
    > The
    > Peebles05
    If you have not already tried it, I would recommend reinstalling the
    drivers for your video card. Assuming you have not added a card to the
    computer, you can get the latest Dell tested driver from our support
    website ('Drivers & Downloads' (http://tinyurl.com/yvb9fn)). Based on
    the replies above the video driver update fixes the problem.
    Larry
    DellCA
  9.    04 Apr 2008 #9
    mossara Guest
    I had the described, very irritating, inconsistant cursor problem for
    three months, ever since I first installed my new Inspiron 530 early
    Jan. 2008. I searched for a solution a few times, but always thought
    it was due to something with the mouse or its driver. And never had
    time to look into it further. Finally, as my sanity was in question
    due to the constant irritation of dealing with repositioning the
    cursor as it seemingly randomly was off by a quarter inch or flew off
    to the corner of the screen, I found time to search for a solution.
    This thread pointed me to the solution! I reinstalled the video
    driver, and at last I have a normal, accurate mouse cursor.
    I must add, that I hesitated to install the driver because my system
    has the "ATI Radeon HD 2600 XT", and the 2600 XT driver in the list of
    recommended drivers to install was listed as an AMD driver. A quick
    check on Wikipedia showed me that ATI was taken over by AMD, so they
    are the same.
    So far, all seems well. What a relief.
    Sara
    > Larry
Mouse Cursor inaccurate
I just got a Dell with 256MB Radeon HD 2600 XT video card. The mouse cursor, is inaccurate... either I need to move the mouse a little to the...
Vista General
Mouse cursor problem!
Hello! I have a very strange problem. The active point of the mouse cursor is not where the cursor appears. The cursor I see is about 1 cm to the...
Vista General
The mouse cursor and the mouse hot spot are not the same location.
This is a weird problem, but my mouse cursor and the mouse hot spot are not the same location. The actual hot spot is 16 pixels up and 16 pixles to...
Vista hardware & devices
Bluetooth mouse/kb intermittent docked notebook dual monitor
I have been having an issue with my MS bluetooth mouse/kb combination temporarily ceasing to function on my notebook (internal bluetooth) when...
mouse cursor disappears
Where does my mouse cursor go when I'm using the pictures slideshow function? I'm not able to see it. I know its there. I've unsuccessfully tried...
Vista General
Intermittent loss of mouse
I am running Windows Vista Home Premium Editon and it keeps losing the mouse, randomly and intermitently. Is there a solution it can be annoying on...
Vista General
Flip 3D and mouse cursor
I have 2 user accounts on a machine. On one, the Flip 3D works perfect, and I can bring windows into the foreground by clicking them with the mouse....
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
