Vista - RE: System restore point - long time.
Old 01-16-2008   #1 (permalink)
Zanzurri
I am having the same problem - especially when it is trying to install
updates from windows. It is taking over an hour. I don't think this is
normal. Does anyone have any suggestions?
Dee
"Rol" wrote:
Quote:
> Hello,
> I have Windows Vista Home Premium installed in my laptop. Vista is installed
> in my C: drive, where all my files are (I didn't do any partition of the
> drive).
> The process of creating a system restore point (system volume information)
> takes a long time, sometimes even 15 minutes and more. While this happens,
> the system works much slower, probably due to the extensive use of the hard
> drive.
> The creation of a system restore point occurs after install / uninstall of a
> program, but also seems to occur randomly, without any obvious reason.
> Is it normal for this to take such a long time? Is it recommended to turn
> the system restore off? Is it possible to control when a system restore point
> is created?
> Thank you
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore Point - how long General Discussion
System Restore error (create restore point), event ID: 8193 Vista General
shadow copy time out when trying to create system restore point Vista performance & maintenance
System restore process takes a long time Vista General
