| | help sidebar using 70% cpu Windows Vista Sidebar doesn't display on my desktop and is eating between 50-75% of my cpu. I can't find a way to uninstall it or reinstall it. Does anyone have any ideas on what I can do?? Thanks. |
| | Re: help sidebar using 70% cpu try running msconfig from the start menu run command. go to startup and make sure there are no entries that point to windows sidebar. If you don’t see any entries in this list, then just to make sure, run the sidebar and then right click the tray icon, and select properties, and deselect "Start sidebar when windows starts." hope this helps, guitardude "LongJakk" <LongJakk@xxxxxx> wrote in message news:F7DD1B35-AB5C-42FE-A107-7964B0C5BA05@xxxxxx Quote: > Windows Vista Sidebar doesn't display on my desktop and is eating between > 50-75% of my cpu. I can't find a way to uninstall it or reinstall it. > Does > anyone have any ideas on what I can do?? Thanks. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: help sidebar using 70% cpu See if this will help you. You may need to "End Process" the sidebar.exe file in Task Manager if it is still using your CPU without being displayed. Windows Sidebar will not Start in Vista Shawn |
| | Re: help sidebar using 70% cpu It actually looks like Sidebar is trying to run 50+ copies of Calendar. I can't tell how many there are because it locks up before I can scroll down to the bottom. Does anyone know if there is a way to edit the list of gadgets to run outside of doing it thru the properties? ie. a bat file or xml file? I tried to do it thru properties, but it stops responding and I have to kill it thru Task Manager. For now, I've de-selected the run on startup option to avoid Sidebar all together. "brink" wrote: Quote: > > LongJakk;576153 Wrote: Quote: > > Windows Vista Sidebar doesn't display on my desktop and is eating > > between > > 50-75% of my cpu. I can't find a way to uninstall it or reinstall it. > > Does > > anyone have any ideas on what I can do?? Thanks. > Hi LongJakk, > > See if this will help you. You may need to "End Process" the > sidebar.exe file in Task Manager if it is still using your CPU without > being displayed. > > Windows Sidebar will not Start in Vista > > Shawn > > > -- > brink > > *There are no dumb questions, just the people that do not ask them.* > '*Vista Forums*' > (http://www.vistax64.com/index.php?referrerid=2980) > *Please post feedback to help others.* > |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: help sidebar using 70% cpu It actually looks like Sidebar is trying to run 50+ copies of Calendar. I can't tell how many there are because it locks up before I can scroll down to the bottom. Does anyone know if there is a way to edit the list of gadgets to run outside of doing it thru the properties? ie. a bat file or xml file? I tried to do it thru properties, but it stops responding and I have to kill it thru Task Manager. For now, I've de-selected the run on startup option to avoid Sidebar all together. "brink" wrote: Quote: > > LongJakk;576153 Wrote: > > Hi LongJakk, > > See if this will help you. You may need to "End Process" the > sidebar.exe file in Task Manager if it is still using your CPU without > being displayed. > > Windows Sidebar will not Start in Vista > > Shawn > > > -- > brink > > *There are no dumb questions, just the people that do not ask them.* > '*Vista Forums*' > (http://www.vistax64.com/index.php?referrerid=2980) > *Please post feedback to help others.* > You can try running do a System Restore using a restore point dated before this happened, or run a Repair install to fix Windows Sidebar. System Restore - How to Repair Install For Vista Shawn |
| Sidebar | Vista General | |||
| Help with SideBar ^_^ | Vista General | |||
| Sidebar | General Discussion | |||
| Google sidebar vs. Windows Vista sidebar | Vista General | |||
| Theme your sidebar: Windows Sidebar Styler | Vista General | |||
