| | Confirmation window not on top When I am downloading an application and one of the (far too many) confirmation windows opens asking me to again confirm that it was really me that requested a certain download, the little window opens behind whatever bigger windows happen to be open and I do not see the confirmation request. How can I force this confirmation window to appear on top of all other windows? (Even better yet, how can I remove it from the operating system?) |
| | Re: Confirmation window not on top Hi, You can't force it, it would normally appear on top anyways, but sometimes the z order gets screwed up by a program's installer. You just have to watch the taskbar for those instances. By the way, it's "installing", not "downloading" when you are running an application setup, and the simplest way to avoid additional messages is to run setup as an administrator by right clicking the setup file and selecting that option. If you are running setup directly from a web download (which is something I recommend never be done), then you will get multiple instances as it will need both permission to run and then permission to access, create, or alter system folders and files. You can disable these prompts by turning off UAC from the tools tab of msconfig, but this is not a wise move. First, it opens the system to unseen modification by any malware that happens to manage to insinuate itself, and defeats the entire security model built for Vista. Second, properly written applications expect it to be there and may not install and function properly if it's not active. Under normal runtime, those messages should be very infrequent and only encountered mainly when installing new software or when running an incompatible program hard-coded to use system folders (and actually there is a method to disable it for a specific application if needed). -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "john3347" <john3347@xxxxxx> wrote in message news:508E80F7-1C24-4E8D-B16A-4B506C9EBA08@xxxxxx Quote: > When I am downloading an application and one of the (far too many) > confirmation windows opens asking me to again confirm that it was really > me > that requested a certain download, the little window opens behind whatever > bigger windows happen to be open and I do not see the confirmation > request. > How can I force this confirmation window to appear on top of all other > windows? (Even better yet, how can I remove it from the operating > system?) |
| | Re: Confirmation window not on top Thank You very much. You have completely and adequately answered my question. Just one more thing that we hate about Vista but will have to live with if we are going to live with Vista, I guess. I am satisfied that you are correct that it is actually during the install process, rather than download process when this happens. Even tho I don't like the answer, I do appreciate your answering the question for me. Thank You. "Rick Rogers" wrote: Quote: > Hi, > > You can't force it, it would normally appear on top anyways, but sometimes > the z order gets screwed up by a program's installer. You just have to watch > the taskbar for those instances. By the way, it's "installing", not > "downloading" when you are running an application setup, and the simplest > way to avoid additional messages is to run setup as an administrator by > right clicking the setup file and selecting that option. If you are running > setup directly from a web download (which is something I recommend never be > done), then you will get multiple instances as it will need both permission > to run and then permission to access, create, or alter system folders and > files. > > You can disable these prompts by turning off UAC from the tools tab of > msconfig, but this is not a wise move. First, it opens the system to unseen > modification by any malware that happens to manage to insinuate itself, and > defeats the entire security model built for Vista. Second, properly written > applications expect it to be there and may not install and function properly > if it's not active. Under normal runtime, those messages should be very > infrequent and only encountered mainly when installing new software or when > running an incompatible program hard-coded to use system folders (and > actually there is a method to disable it for a specific application if > needed). > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "john3347" <john3347@xxxxxx> wrote in message > news:508E80F7-1C24-4E8D-B16A-4B506C9EBA08@xxxxxx Quote: > > When I am downloading an application and one of the (far too many) > > confirmation windows opens asking me to again confirm that it was really > > me > > that requested a certain download, the little window opens behind whatever > > bigger windows happen to be open and I do not see the confirmation > > request. > > How can I force this confirmation window to appear on top of all other > > windows? (Even better yet, how can I remove it from the operating > > system?) > |
| | Re: Confirmation window not on top The prompts can be turned off without disabling UAC. "Rick Rogers" <rick@xxxxxx> wrote in message Quote: > > You can disable these prompts by turning off UAC from the tools tab of > msconfig, but this is not a wise move. First, it opens the system to > unseen modification by any malware that happens to manage to insinuate > itself, and defeats the entire security model built for Vista. |
| Re: How Do I Get A Confirmation of Delivery | Live Mail | |||
| Log off confirmation | Vista General | |||
| Recycle Bin confirmation | Tutorials | |||
| Windows Confirmation | Vista mail | |||
| UAC failed to ask for confirmation. Bug? | Vista security | |||
