| | Desktop does not load after login Options I've check event viewer, but it does not show out any error msg. Then I try to create another user account as admin. Yet the result still the same. After the User login, desktop does not load, showing blank windows. No right click mouse function. But Ctr+ALT+Del still can work with Task Manager. Pls Help. I really need an advise here. |
| | Re: Desktop does not load after login Options Victor, I imagine you have probably performed a reinstall by now. Hopefully this will help somebody else. I'm am having the same issue. What I have done as a work around is to ctl-alt-dlt to get into task manager then goto File>New Task> and start explorer.exe from there. Vista shows the desktop and loads all of my startup and everything works great. Sarafee, I'm not 100% that it is the firewall doing this, I'm using AVG9 IS and have disabled Vista, tried it the opposite way and have disabled both and seem to have the same symptoms. I'll let you know what I;ve come up with. -- GlenS1201 ------------------------------------------------------------------------ GlenS1201's Profile: http://forums.techarena.in/members/glens1201.htm View this thread: http://forums.techarena.in/vista-help/895952.htm http://forums.techarena.in |
| | Re: Desktop does not load after login Options GlenS1201;100036 Wrote: Quote: > Victor, I imagine you have probably performed a reinstall by now. > Hopefully this will help somebody else. I'm am having the same issue. > What I have done as a work around is to ctl-alt-dlt to get into task > manager then goto File>New Task> and start explorer.exe from there. > Vista shows the desktop and loads all of my startup and everything > works > great. > > Sarafee, I'm not 100% that it is the firewall doing this, I'm using > AVG9 IS and have disabled Vista, tried it the opposite way and have > disabled both and seem to have the same symptoms. I'll let you know > what > I;ve come up with. > > > -- > GlenS1201 > ------------------------------------------------------------------------ > GlenS1201's Profile: 'GlenS1201's profile on TechArena Computer > Hardware Support Forums of India' > (http://forums.techarena.in/members/glens1201.htm) > View this thread: 'Desktop does not load after login Options - Vista > Help' (http://forums.techarena.in/vista-help/895952.htm) > > 'TechArena Community - Technology and Computer Hardware Support Forums > of India' (http://forums.techarena.in) -- Ramesh Kumar MVP RAMESH KUMAR Microsoft MVP: 'My MVP Profile' (https://mvp.support.microsoft.com/profile/Ramesh.Kumar) My Blog: 'It's My Windows' (http://itsmywindows.com) ------------------------------------------------------------------------ Ramesh Kumar MVP's Profile: http://winvistaclub.com/forum/member.php?userid=17 View this thread: http://winvistaclub.com/forum/showthread.php?t=22301 |
| | Re: Desktop does not load after login Options Go here download and run this script: http://www.paulsxp.com/forum/viewtopic.php?f=16&t=142 This script will add the explore.exe back to the shell, Vista. -- --------------------------------------------------------------------------------- www.paulsxp.com www.paulsxp.com/forum www.supportspace.com/home/home.s2?aiu=paulm --------------------------------------------------------------------------------- "GlenS1201" <GlenS1201.3fv0vc@xxxxxx> wrote in message news:GlenS1201.3fv0vc@xxxxxx Quote: > > Victor, I imagine you have probably performed a reinstall by now. > Hopefully this will help somebody else. I'm am having the same issue. > What I have done as a work around is to ctl-alt-dlt to get into task > manager then goto File>New Task> and start explorer.exe from there. > Vista shows the desktop and loads all of my startup and everything works > great. > > Sarafee, I'm not 100% that it is the firewall doing this, I'm using > AVG9 IS and have disabled Vista, tried it the opposite way and have > disabled both and seem to have the same symptoms. I'll let you know what > I;ve come up with. > > > -- > GlenS1201 > ------------------------------------------------------------------------ > GlenS1201's Profile: http://forums.techarena.in/members/glens1201.htm > View this thread: http://forums.techarena.in/vista-help/895952.htm > > http://forums.techarena.in > |
| | Re: Desktop does not load after login Options Ramesh Kumar MVP;3978365 Wrote: Quote: > GlenS1201;100036 Wrote: Quote: > > Victor, I imagine you have probably performed a reinstall by now. > > Hopefully this will help somebody else. I'm am having the same Quote: > > What I have done as a work around is to ctl-alt-dlt to get into task > > manager then goto File>New Task> and start explorer.exe from there. > > Vista shows the desktop and loads all of my startup and everything > > works > > great. > > > > Sarafee, I'm not 100% that it is the firewall doing this, I'm using > > AVG9 IS and have disabled Vista, tried it the opposite way and have > > disabled both and seem to have the same symptoms. I'll let you know > > what > > I;ve come up with. > > > > > > -- > > GlenS1201 > > Quote: > > GlenS1201's Profile: 'GlenS1201's profile on TechArena Computer > > Hardware Support Forums of India' > > (http://forums.techarena.in/members/glens1201.htm) > > View this thread: 'Desktop does not load after login Options - Vista > > Help' (http://forums.techarena.in/vista-help/895952.htm) > > > > 'TechArena Community - Technology and Computer Hardware Support Quote: > > of India' (http://forums.techarena.in) > Are you sure ? Its AVG9 > > > -- > Ramesh Kumar MVP > > RAMESH KUMAR > Microsoft MVP: 'My MVP Profile' > (https://mvp.support.microsoft.com/profile/Ramesh.Kumar) > My Blog: 'It's My Windows' (http://itsmywindows.com) > ------------------------------------------------------------------------ > Ramesh Kumar MVP's Profile: > http://winvistaclub.com/forum/member.php?userid=17 > View this thread: http://winvistaclub.com/forum/showthread.php?t=22301 Paul, thanks for the script that seems to have fixed my problem. -- GlenS1201 ------------------------------------------------------------------------ GlenS1201's Profile: http://forums.techarena.in/members/glens1201.htm View this thread: http://forums.techarena.in/vista-help/895952.htm http://forums.techarena.in |
| | #6 (permalink) |
| | Re: Desktop does not load after login Options You are welcome. -- --------------------------------------------------------------------------------- www.paulsxp.com www.paulsxp.com/forum www.supportspace.com/home/home.s2?aiu=paulm --------------------------------------------------------------------------------- "GlenS1201" <GlenS1201.3fx13e@xxxxxx> wrote in message news:GlenS1201.3fx13e@xxxxxx Quote: > > Ramesh Kumar MVP;3978365 Wrote: Quote: >> GlenS1201;100036 Wrote: Quote: >> > Victor, I imagine you have probably performed a reinstall by now. >> > Hopefully this will help somebody else. I'm am having the same Quote: >> > What I have done as a work around is to ctl-alt-dlt to get into task >> > manager then goto File>New Task> and start explorer.exe from there. >> > Vista shows the desktop and loads all of my startup and everything >> > works >> > great. >> > >> > Sarafee, I'm not 100% that it is the firewall doing this, I'm using >> > AVG9 IS and have disabled Vista, tried it the opposite way and have >> > disabled both and seem to have the same symptoms. I'll let you know >> > what >> > I;ve come up with. >> > >> > >> > -- >> > GlenS1201 >> > Quote: >> > GlenS1201's Profile: 'GlenS1201's profile on TechArena Computer >> > Hardware Support Forums of India' >> > (http://forums.techarena.in/members/glens1201.htm) >> > View this thread: 'Desktop does not load after login Options - Vista >> > Help' (http://forums.techarena.in/vista-help/895952.htm) >> > >> > 'TechArena Community - Technology and Computer Hardware Support Quote: >> > of India' (http://forums.techarena.in) >> Are you sure ? Its AVG9 >> >> >> -- >> Ramesh Kumar MVP >> >> RAMESH KUMAR >> Microsoft MVP: 'My MVP Profile' >> (https://mvp.support.microsoft.com/profile/Ramesh.Kumar) >> My Blog: 'It's My Windows' (http://itsmywindows.com) >> ------------------------------------------------------------------------ >> Ramesh Kumar MVP's Profile: >> http://winvistaclub.com/forum/member.php?userid=17 >> View this thread: http://winvistaclub.com/forum/showthread.php?t=22301 > My apologies, a typo. It is AVG 8. > > Paul, thanks for the script that seems to have fixed my problem. > > > -- > GlenS1201 > ------------------------------------------------------------------------ > GlenS1201's Profile: http://forums.techarena.in/members/glens1201.htm > View this thread: http://forums.techarena.in/vista-help/895952.htm > > http://forums.techarena.in > |
| Can't Load Vista Disc For Repair Options | Vista installation & setup | |||
| Login screen fails to load | Vista General | |||
| Login process has failed to create the security options | Vista General | |||
| Vista Desktop Wallpaper Fit options, I thought there were 5 options? | General Discussion | |||
| Login Options | Vista General | |||
