Vista - default programs --- explorer crashes! and a question about system restore too...
Old 01-22-2008   #1 (permalink)
Neerav
i am using windows vista ultimate and no updates have been installed.
whenever i try opeaning "Associate a file type or protocol with a program"
under default programs in control panel explorer crashes. i try to search
for online solutions but nothing seems to happen. what could be the problem?
in all other ways the system works fine.
also, reently i check the system restore window and i learnt my system has
only 3 restore points. the last time i used my system was on 14th jan and
that was the last system restore point created. i installed vista last
december so i was expecting some more restore points. i have not manually
deleted any and have also not disabled system point at any time. can anyone
comment on it?
thanks in advance.
Neerav
Old 01-22-2008   #2 (permalink)
Windows Vista x64 Ultimate
Re: default programs --- explorer crashes! and a question about system restore too...
Quote  Quote: Originally Posted by Neerav View Post
comment on it?
thanks in advance.
Neerav
Perform a complete Windows Update. And continue executing Windows Update untill it says there are no more updates available.
When you have done this, report back whether your problem has been solved or not.
Or is there a specific reason why you have not yet run Windows Update...
Old 01-22-2008   #3 (permalink)
~Alex~.:MVP Windows Shell/User:.
Agreed. Run Update and gat all the updates needed. Should be about 40 or
50 updates. One of the updates could possibly fix your issue. Other than
that try to create a restore point manually.
~Alex T~
..:~A.K.A. Makaveli213~:.
..:MVP Windows Shell/User:.
"dzomlija" <dzomlija.33l6e4@xxxxxx-mx.forums.net> wrote in message
news:dzomlija.33l6e4@xxxxxx-mx.forums.net...
Quote:
>> program"
>> search
>> problem?
>> has
>> and
>> manually
>> anyone
>> comment on it?
>> thanks in advance.
>> Neerav
> -*Perform a complete Windows Update*-. And continue executing Windows
> solved or not.
> Update...
> dzomlija
> _____________________
> Peter Alexander Dzomlija
> -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as
> you die, so shall I be Reborn...-
> -Download MP3 Media Properties Explorer: --http://www.phx.co.za-
> - ASUS A8N32-SLI-Deluxe
> - AMD Athlon 64 Dual-Core 4800+
> - 4GB DDR400
> - 128MB ASUS nVidia 6600
> - Thermaltake Tai-Chi Chassis
> - 1207GB Formatted Storage
> - Vista Ultimate x64
> - CodeGear Delphi 2007See my rig at:
> http://s229.photobucket.com/albums/e...zomlija/Venus/
Re: Windows Mail - Restore or Remove from Default Programs Browsers & Mail
Internet Explorer - Restore or Remove from Default Programs Tutorials
default programs --- explorer crashes! and a question about system restore too... Vista General
programs won't launch, but appear when explorer crashes and restar Vista General
Right clicking in startmenu all programs crashes Explorer Vista performance & maintenance
