Vista - HELP!! I lost my Ultimate Extra's after repair....
Old 01-22-2008   #1 (permalink)
MasterPC99
I upgraded my system from MCE to Ultimate 64bit and all was fine till I
tried reinstallig a game GT Ledgends (GTL) which uses a copy protection that
is not vista freindly. Consiquently, I needed run repair to get the system up
again. Unfortunately, the restore broght me back to a point before I
installed the Ultimate Extras and now I can't get them back.
Any help would be apppreciated.
Thanks
Old 01-22-2008   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: HELP!! I lost my Ultimate Extra's after repair....
Rename the SoftwareDistribution folder. (Because of possible folder
corruption or other errors.)
Click Start, Choose Run.
In the Run box, type services.msc.
Click OK.
Right-click the Automatic Updates service.
Click Stop.
Stopping the service will take a moment.
Rename the "SoftwareDistribution" folder:
a. Click Start, click Run, type %systemroot%, and then click OK.
b. Right-click the SoftwareDistribution folder, and then click Rename.
c. Type SoftwareDistribution.old, and then press ENTER to rename this
folder.
Create a new folder called "SoftwareDistribution"
Click Start. Choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
Rerun Windows Update.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"MasterPC99" <MasterPC99@xxxxxx> wrote in message
news10409A6-0A4C-488B-B5CE-4A9027DA03C9@xxxxxx
Quote:
> Hi,
> that
> up
> Thanks
Solved tried to do a vista repair install - lost user settings, installed programs etc. General Discussion
Lost Ultimate Extras after repair Help! Vista General
Windows Vista Business Repair Disk LOST !!! HELP Vista installation & setup
no ultimate extra's showing up Vista General
Ultimate Extra's load Windows Update?? Vista General
