Vista - default programs --- explorer crashes! and a question about system restore too...
Old 01-22-2008   #1 (permalink)
Neerav
i am using windows vista ultimate and no updates have been installed.
whenever i try opeaning "Associate a file type or protocol with a program"
under default programs in control panel explorer crashes. i try to search
for online solutions but nothing seems to happen. what could be the problem?
in all other ways the system works fine.
also, reently i check the system restore window and i learnt my system has
only 3 restore points. the last time i used my system was on 14th jan and
that was the last system restore point created. i installed vista last
december so i was expecting some more restore points. i have not manually
deleted any and have also not disabled system point at any time. can anyone
comment on it?
thanks in advance.
Neerav
Re: Windows Mail - Restore or Remove from Default Programs Browsers & Mail
Internet Explorer - Restore or Remove from Default Programs Tutorials
default programs --- explorer crashes! and a question about system restore too... Vista General
programs won't launch, but appear when explorer crashes and restar Vista General
Right clicking in startmenu all programs crashes Explorer Vista performance & maintenance
