| | renaming files problem.. Vista is not letting me rename a folder, it says one some files inside are open in a program but I don't have any files open in any program.. XP used to do the same thing; what is solution here, pls.. thanks............ |
| | Re: renaming files problem.. Have a look at Task Manager to see if a related Process is running. "maya" <maya778899@xxxxxx> wrote in message news:fn84if$gkb$1@xxxxxx Quote: > > Vista is not letting me rename a folder, it says one some files inside are > open in a program but I don't have any files open in any program.. XP used > to do the same thing; what is solution here, pls.. > > thanks............ > > > |
| | Re: renaming files problem.. This will happen if you have a folder selected above the file or folder you want to rename. Select the file or folder you want to rename, then rename it. Right clicking and choosing rename does not select the folder or file. "maya" <maya778899@xxxxxx> wrote in message news:fn84if$gkb$1@xxxxxx Quote: > > Vista is not letting me rename a folder, it says one some files inside are > open in a program but I don't have any files open in any program.. XP used > to do the same thing; what is solution here, pls.. > > thanks............ > > > |
| | Re: renaming files problem.. maya <maya778899@xxxxxx> wrote in news:fn84if$gkb$1@xxxxxx: Quote: > > Vista is not letting me rename a folder, it says one some files inside > are open in a program but I don't have any files open in any program.. > XP used to do the same thing; what is solution here, pls.. > > thanks............ Next, does it tell you what files are in use ? If not, you can try to move all the files into a temp folder and the one(s) that won't move are in use. Note the filenames of the 'in use' one(s). You can d/l Sysinternals Process Explorer from MS and use that to find what process is using the files. PE does not need to be installed, just unzipped to a folder. PE is a task manager replacement that is far more capable than MS task manager. Start PE, goto 'Find' menu, select 'Find DLL or Handle'. A box will pop up to enter a search into. Enter the file name that would not move, press return or click 'Search'. The bottom of the box will fill with any process(es) that have that file open. After you find which process is using the file(s), we can look inot it more. |
| | Re: renaming files problem.. "AlexB" <alexb@xxxxxx> wrote in news:e0EPtYhXIHA.4868@xxxxxx: Dude....WTF ?! Can you not understand anything ? Quote: > This person went on a tangent. Quote: > > The OP DOES NOT HAVE A FILE NAME. All she has is a folder name which > she is trying to rename. > > When she tries to rename it Vista tells her that there is a lockup on > the folder because it is used by a program. Vista seldom bothers to > tell people who go on a tangent what the file name is. 'Vista is not letting me rename a folder, it says one some files inside are open in a program but I don't have any files open in any program.. XP used to do the same thing; what is solution here, pls..' The OP there says Vista says there are files in use in the folder, DUH! I'm only going by what I was told in the OP. I'm not making up a bunch of different scenarios of what they could have possibly meant. I am answering the question as it is posed. Nothing more, nothing less. Quote: > This is what she's got. No more no less. > > It is actually plenty. Yes, one way to test if Vista was serious is to > reboot the system. I kind of suspect she has already done it. Let's > assume she did and the issue remains unresolved. No file name, only > folder. What are you going to do? or nay. Quote: > > You first make sure ALL files are displayed even if those files are > secret system files and I showed how to do it in my previous post. seriously doubt they made any files read only or hidden manually. Quote: > She can look inside the folder and see if any files appeared. Let's > assume they did. Then she has to assign permissions to herself to > rename them. Strictly speaking she does not need to take cover off all > the Vista files for that. All she needs is to give herself elevated > permission. She can actually do it in Command Prompt "Run as > administrator" and try to rename the folder. I bet it won't work. She > will have to then assign herself as a user with full rights in Windows > Explorer: Property>>Security Tab>>Edit>Add User>>Full Right>>Apply. > > She can (I believe) do her rename even if Vista has a file stashed in > that folder which it is using provided she has all elevated > privileges. Quote: > Task manager does not appear to be any logical choice since the name > of the application (exec file) is unknown. Aside it may be a database > file or a log file. The name of the file in that folder most likely > has nothing to do with the process in the task Manager. read the post, you will see....well probably not. Let me refresh your tiny fish-sized memory. I said DON'T use Task Manager, but instead use Process Explorer, and then went on to explain how you can find the process, if you know the name of the file, if you know the name of the file, if you know the name of the file. Quote: > If after she made sure ALL files are displayed by Vista and still > there is no file in there then she has to look into the registry. It > is an arduous process but again the task manager may not be of any > help if there is a lockup on that nonexistent file somewhere up in the > registry. in it and the locked folder can't be resolved and it's not a system folder, instead of wasting what could be hours worth of researching for a fix and manual registry searching here's what I would do...... I'd boot from Win98 boot floppy, start the free utility NTFS4DOS, CD to the parent folder of the offending folder, do an RD and then a MKDIR with the new name. That would take 5 minutes, at most, since I already have a Win98 boot disk with NTFS4DOS on it, and quicker than slaving the drive into another PC. So now, please stop picking apart my posts if you don't *completely* understand what is being said. |
| Renaming files | VB Script | |||
| Renaming Files | Vista General | |||
| Problem Renaming Multiple Files in Vista | Vista General | |||
| Problem with renaming files ! | PowerShell | |||
