Vista - Hotfix from MS - slove the sleep problem
Old 01-25-2008   #1 (permalink)
Bernard Liengme
If I hit the Sleep (hibernate) key on my HP desktop, the PC does into
hibernation. Hitting the key again will not wake it up - I get a reboot.
Have lost work by mistakenly hitting Sleep when I wanted ESC! The key now
has a jar lid taped over it.
When the PC reboots there is a message blaming the problem on my NVIDEA
graphic card.
Has anyone used the MS hotfix for this problem ? Should I try it?
Bernard V Liengme
Microsoft Excel MVP
www.stfx.ca/people/bliengme
remove caps from email
SP2 hotfix problem Windows Updates
get-hotfix return 'The term 'get-hotfix' is not recognized' PowerShell
must have hotfix? Vista General
Hotfix for wireless connection problem Vista General
Vista Sleep Problem / Network Problem Vista networking & sharing
