| Guest | is there a way to disable shadow copy but retain restore point function I am reading on some sites about shadow copies and how you have old versions of each file I dont want this function because I want the pc to go faster.. how can I disable this without removing the restore point functionality? In other words I want Vista to behave like XP did, where you had restore points but not old versions of files.. thanks |
| Administrator | Re: is there a way to disable shadow copy but retain restore point function I am reading on some sites about shadow copies and how you have old versions of each file I dont want this function because I want the pc to go faster.. how can I disable this without removing the restore point functionality? In other words I want Vista to behave like XP did, where you had restore points but not old versions of files.. thanks You can disable one of the other Services other than "Volume Shadow Copy" in this tutorial to stop the Previous Versions from working. You cannot stop them from being created and stored without disabling System Restore to. Previous Versions - Shadow Copy You can also adjust how much space is used on your hard drive for the restore points (System Restore) and Previous Versions (Shadow Copy). System Restore - disk space Shawn |
| Resistance is Futile | Re: is there a way to disable shadow copy but retain restore point function I am reading on some sites about shadow copies and how you have old versions of each file I dont want this function because I want the pc to go faster.. how can I disable this without removing the restore point functionality? In other words I want Vista to behave like XP did, where you had restore points but not old versions of files.. thanks It's sort of like a souped-up "Recycle Bin" that works even when you don't delete files. Have you ever edited and saved a Word document, or saved some other file when you didn't really want to? Normally that type of screw-up would mean the original file that you wanted to keep is gone. Shadow Copies is the perfect means with which to recover these files, and can in some instances when used on an entire folder, recover files that you deleted and then emptied from the Recycle Bin. Many people feel that they are "experienced enough" to not make such a blunder. But trust me - The next time you're in a hurry, or are under pressure to complete a specific task, you can and will make mistakes that will leave you wishing you had Shadow Copies enabled to help you recover. Just my two-cents worth... |
| shadow copy time out when trying to create system restore point | Vista performance & maintenance | |||
| shadow copy / restore thingy archives exactly what? | Vista General | |||
| System Restore Points without shadow copy - there has got to be a way!! | Vista file management | |||
| System Restore Points without shadow copy - there has got to be a way!! | Vista General | |||
| Finding shadow copy and restore point snapshots | Vista file management | |||
