"Neil" wrote:
> I did not make any changes on my computer. I start it up and get a message
> from the Windows boot manager saying
> Windows failed to start. A recent hardware or software change might be the
> cause.
> Status: 0xc000000f
> Info: Windows failed to start.load because the NLS data is missing or corrupt.
> The Windows boot manager suggest inserting the Windows VISTA DVD and doing a
> repair. The problem is that I did the upgrade using a download from Windows
> Marketplace. I have no Vista DVD. What can I do? I tried all options in
> the Windows Boot Manager. There are no repair options without the
> installation disc.
Neil,
Try booting with the F8 key or F12 key and see what your options are.
You should have a repair option or the option to use the "last known good
configuration."
I've never used Windows Marketplace. You may have the option to
redownload your OS onto a CD or DVD. I really don't know. Personally, I
refuse to buy a computer from a vendor that ships the computer without an
installation disk or recovery disk, because you can always use the disk to
reinstall the original OS.
Have a nice day.
C.B.
