1.    27 Jan 2008 #1
    jim Guest
    Need copy of Vista Home Premium!
    Is there a web sight were I can get a free trial version of Vista Home
    Premium? Reason is that I have a oem version key on my laptop but it came
    pre installed and I formated drive to rid viruses but oops! Anyway if anyone
    knows were I can get a copy to use for install I can use my product code off
    of the laptop were I will be installing this copy of vista home premium???
    Any help would be appreciated. Can not access recovery partition since I
    formated the os partition?
  2.    27 Jan 2008 #2
    turnstyle Guest
    Re: Need copy of Vista Home Premium!
    Get a copy of the Vista Upgrade Anytime disk -- I got one from CompUSA
    for $5.
    -Scott
  3.    27 Jan 2008 #3
    peter Guest
    Contact the maker of your Latop for CD/DVD copies of your System
    Recovery............or read the manual on how to restore from the Recovery
    Partition.
    Some makers have you push an F? on startup to instantly start the recovery
    process.
    Since you did not name the Laptop its hard to get specific
    peter
    DISCLAIMER: If you find a posting or message from me
    offensive, inappropriate, or disruptive, please ignore it.
    If you don't know how to ignore a posting, complain to
    me and I will be only too happy to demonstrate... ;-)
    "jim" <jmlvy1@xxxxxx> wrote in message
    news:BB75B29B-B45D-462D-9641-CC799E516B97@xxxxxx
    > anyone knows were I can get a copy to use for install I can use my product
    > code off of the laptop were I will be installing this copy of vista home
    > premium??? Any help would be appreciated. Can not access recovery
    > partition since I formated the os partition?
  4.    27 Jan 2008 #4
    BillD Guest
    RE: Need copy of Vista Home Premium!
    order the dvd from this site:
    http://www.microsoft.com/windows/pro.../overview.mspx
  5.    27 Jan 2008 #5
    jim Guest
    Thanks for info to all! I tried installing my copy of vista home basic which
    works fine except in 30 days it will be dead because i can't activate do to
    it being installed on my desktop computer? Contacting the manufacturer is a
    good option for me. Just looking for a different fix. I tried upgrade online
    except my copy on the laptop is not activated? Keep sending me ideas and
    hopefully some one will give me a link i can go to to download a trial
    version so i can find out if microsoft will honor the oem numbers on my
    laptop? Thank you to all who inform!
    "peter" <peterk@xxxxxx> wrote in message
    news:CE7D816D-E6DD-4158-81E7-F7106955A0B1@xxxxxx
    > Partition.
    > process.
    > peter
    >> product code off of the laptop were I will be installing this copy of
    >> vista home premium??? Any help would be appreciated. Can not access
    >> recovery partition since I formated the os partition?
  6.    27 Jan 2008 #6
    jim Guest
    Scott,
    How is the anytime disk different from upgrading online?
    "turnstyle" <turnstyle@xxxxxx> wrote in message
    news:89ee950e-3387-4040-b56d-2e997addc6e6@xxxxxx
    > for $5.
    > -Scott
  7.    27 Jan 2008 #7
    Rick Rogers Guest
    1) Contact the system manufacturer for instructions on accessing the
    recovery partition or to obtain an appropriate recovery disk set. Why?
    2) Your OEM product key is not going to work with a retail version of the
    product even if a free trial download were available (it's not, but that's
    besides the point). An OEM key needs to be used with OEM media.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    My thoughts http://rick-mvp.blogspot.com
  8.    27 Jan 2008 #8
    Bill Guest
    > which works fine except in 30 days it will be dead because i can't
    > activate do to it being installed on my desktop computer? Contacting
    > the manufacturer is a good option for me. Just looking for a different
    > fix. I tried upgrade online except my copy on the laptop is not
    > activated? Keep sending me ideas and hopefully some one will give me a
    > link i can go to to download a trial version so i can find out if
    > microsoft will honor the oem numbers on my laptop? Thank you to all who
    > inform!
    You have a disc for Vista Home Basic then? That disc can be used to
    install Home Premium. Just key in your Home Premium registration key
    when prompted, and it should work.
    Once it is installed, your product key, if it's like the OEM key that
    came with my Acer, may not activate if you attempt internet activation.
    You'll probably be prompted to call Microsoft's toll-free number.
  9.    27 Jan 2008 #9
    jim Guest
    Thank you Rick for this info. Looks like Dell wins?
    "Rick Rogers" <rick@xxxxxx> wrote in message
    news:eJCls$PYIHA.4896@xxxxxx
    > Hi,
    > Best of Luck,
  10.    27 Jan 2008 #10
    Rick Rogers Guest
    I stopped recommending them long ago, the hardware's not what it used to be.
    Best of Luck,
    news:6BD6FDA0-14C4-48D4-8D14-BB98AFFE09F9@xxxxxx
    >> Hi,
    >> that's besides the point). An OEM key needs to be used with OEM media.
    >> Best of Luck,
    >>> came pre installed and I formated drive to rid viruses but oops! Anyway
    >>> if anyone knows were I can get a copy to use for install I can use my
Page 1 of 2 12 LastLast
Best way to make a copy of a DVD using Vista Home Premium?
As a computer illiterate can someone advise me how best to make a copy of a DVD using Vista Home Premium. DVD in question was created on another...
General Discussion
Can I use Vista Home Premium OEM Licence with full copy?
I have a laptop with Windows Vista Home Premium pre installed and a Recovery CD-ROM. I may be missing something but, as far as I can tell, the...
Vista installation & setup
Upgrading to Vista Home Premium from XP bootleg copy
I will be installing an authorized, legitimate copy of Windows Vista Home Premium on a family members PC. This will be a retail, full...
Vista General
In Vista Home Premium - Can not copy, move, rename or delete a fil
Hello, My problem is this: - In Windows EXPLORER (resource manager) I cannot copy, move, rename or delete some files. - Copy or move -commands...
Vista file management
can i buy or get a copy of windows vista home premium ?
I have bought a comp that has hidden recovery partition , the comp comes with vista premium activation key .... i have no recovery disks or vista...
Vista General
File copy from external XP Pro HD to internal Vista Home Premium H
I need help with step by step instructions on how to perform a file copy from external XP Pro HD to internal Vista Home Premium HD. After some...
Vista account administration
Copy DVD using Home Vista Premium...
Does anyone have a clue how to do this...I want to take an existing DVD and burn it to a blank DVD.
Vista music pictures video
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
