Vista - Remote desktop from XP to Vista using NLA
Old 07-31-2006   #1 (permalink)
=?Utf-8?B?U3VwZXJQbGF5?=
In Vista build 5384 it states in the help that there is a service pack for
down level clients (I am interested in XP) to add the ability for remote
destkop connection to connect to Vista clients using NLA.
Where do I get this service pack from for XPSP2?
From Help:
"Select Allow connections only from computers running Remote Desktop with
Network Level Authentication to allow people with computers running versions
of Remote Desktop or Remote Programs with Network Level Authentication (NLA)
to connect to your computer. (In this version of Windows, Remote Desktop uses
NLA. You can also download NLA as a service pack on computers running some
earlier versions of Windows.)"
Regards
SuperPlay
Old 07-31-2006   #2 (permalink)
Jimmy Brush
Re: Remote desktop from XP to Vista using NLA
Hello,
The remote desktop client upgrade for Windows XP SP2 and Windows Server 2003
is not yet publically available. It is currently in private beta testing.
- JB
Vista Support FAQ
http://www.jimmah.com/vista/
Old 07-31-2006   #3 (permalink)
Thanks for the reply Jimmy :-)
Old 10-19-2006   #4 (permalink)
v plaksin
Thank you for answer.
At least that means that there is no problem with my computer.
But I need RD. What a pity to say goodbye to Vista, it was nice!
Remote desktop can not find remote computer Network & Sharing
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
Is there a program to use remote desktop, or remote assistance "host" on Vista Home? Vista General
remote desktop connection? AKA remote access? Vista General
Remote Desktop - Able to have one user logged in locally and one user via remote desktop? Vista networking & sharing
