| | Admin accounts can't access control panel - please help! I have two user accounts on Vista Home Pro. One is a standard, limited user account (password protected) and the other is my admin account (obviously with admin privileges and password protected). I am not sure when this started happening but I am unable to launch control panel under my admin account. I get a pop-up of "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item". The title bar of this pop-up has "::{26EE0668-A00A-44D7-9371-BEB064C98683}" I can only get to CP from my limited account. Then I am prompted to enter the Admin account's password. At times even trying this fails with the same error the first time I try to launch CP. Usually the second or third time I launch CP it will actually launch. Someone suggested I set up a new admin account and then, from that account, rename the original Admin account's profile so that Windows would rebuild it upon reboot. Well, I did manage to create a new admin account (using admin privileges from my limited account) but even that new admin account can't launch control panel. Interestingly, after I set up the second admin account, when I try an admin cp function from my limited account it does correctly show me a pop-up showing me two admin users to choose for entering the admin password. So it does know the two users as admin accounts. I am at a loss as to what to do/try. Is there a way to repair the OS using the original DVD (I didn't see any applicable repair options) Any help is appreciated. Thanks, Walter |
| | RE: Admin accounts can't access control panel - please help! Take a look at this tutorial. Control Panel - Enable or Disable "Walter Cohen" wrote: Quote: > I have two user accounts on Vista Home Pro. > One is a standard, limited user account (password protected) and the other > is my admin account (obviously with admin privileges and password > protected). > > I am not sure when this started happening but I am unable to launch control > panel under my admin account. > I get a pop-up of "Windows cannot access the specified device, path, or > file. You may not have the appropriate permissions to access the item". > The title bar of this pop-up has "::{26EE0668-A00A-44D7-9371-BEB064C98683}" > > I can only get to CP from my limited account. Then I am prompted to enter > the Admin account's password. At times even trying this fails with the same > error the first time I try to launch CP. Usually the second or third time I > launch CP it will actually launch. > > Someone suggested I set up a new admin account and then, from that account, > rename the original Admin account's profile so that Windows would rebuild it > upon reboot. Well, I did manage to create a new admin account (using admin > privileges from my limited account) but even that new admin account can't > launch control panel. > > Interestingly, after I set up the second admin account, when I try an admin > cp function from my limited account it does correctly show me a pop-up > showing me two admin users to choose for entering the admin password. So it > does know the two users as admin accounts. > > I am at a loss as to what to do/try. Is there a way to repair the OS using > the original DVD (I didn't see any applicable repair options) > > Any help is appreciated. > Thanks, > Walter > > |
| | Re: Admin accounts can't access control panel - please help! This doesn't apply to me. In my Home Pro version there is nothing in Policies other than the default item (type of REG_SZ). Same under HKEY_LOCAL_MACHINE. So NoControlPanel is nowhere to be found. Thanks. Walter "uvbogden" <uvbogden@xxxxxx> wrote in message news:E6029BF9-98FC-4BF2-9626-FB8BE0C6D3C7@xxxxxx Quote: > Take a look at this tutorial. > > Control Panel - Enable or Disable > > "Walter Cohen" wrote: > Quote: >> I have two user accounts on Vista Home Pro. >> One is a standard, limited user account (password protected) and the >> other >> is my admin account (obviously with admin privileges and password >> protected). >> >> I am not sure when this started happening but I am unable to launch >> control >> panel under my admin account. >> I get a pop-up of "Windows cannot access the specified device, path, or >> file. You may not have the appropriate permissions to access the item". >> The title bar of this pop-up has >> "::{26EE0668-A00A-44D7-9371-BEB064C98683}" >> >> I can only get to CP from my limited account. Then I am prompted to >> enter >> the Admin account's password. At times even trying this fails with the >> same >> error the first time I try to launch CP. Usually the second or third >> time I >> launch CP it will actually launch. >> >> Someone suggested I set up a new admin account and then, from that >> account, >> rename the original Admin account's profile so that Windows would rebuild >> it >> upon reboot. Well, I did manage to create a new admin account (using >> admin >> privileges from my limited account) but even that new admin account can't >> launch control panel. >> >> Interestingly, after I set up the second admin account, when I try an >> admin >> cp function from my limited account it does correctly show me a pop-up >> showing me two admin users to choose for entering the admin password. So >> it >> does know the two users as admin accounts. >> >> I am at a loss as to what to do/try. Is there a way to repair the OS >> using >> the original DVD (I didn't see any applicable repair options) >> >> Any help is appreciated. >> Thanks, >> Walter >> >> |
| | Re: Admin accounts can't access control panel - please help! Interestingly, under StartMenu->StartMenu->CascadeControlPanel->Policy there are two items: NoControlPanel and NoSetFolders. Each of these is really empty - just has the default key name 'ab' type 'REGSZ'. This is also the case under StartPanel. Walter "Walter Cohen" <w_cohen@xxxxxx> wrote in message news:%23Hu4CzaYIHA.4684@xxxxxx Quote: > This doesn't apply to me. > In my Home Pro version there is nothing in Policies other than the default > item (type of REG_SZ). > Same under HKEY_LOCAL_MACHINE. > So NoControlPanel is nowhere to be found. > > Thanks. > Walter > "uvbogden" <uvbogden@xxxxxx> wrote in message > news:E6029BF9-98FC-4BF2-9626-FB8BE0C6D3C7@xxxxxx Quote: >> Take a look at this tutorial. >> >> Control Panel - Enable or Disable >> >> "Walter Cohen" wrote: >> Quote: >>> I have two user accounts on Vista Home Pro. >>> One is a standard, limited user account (password protected) and the >>> other >>> is my admin account (obviously with admin privileges and password >>> protected). >>> >>> I am not sure when this started happening but I am unable to launch >>> control >>> panel under my admin account. >>> I get a pop-up of "Windows cannot access the specified device, path, or >>> file. You may not have the appropriate permissions to access the item". >>> The title bar of this pop-up has >>> "::{26EE0668-A00A-44D7-9371-BEB064C98683}" >>> >>> I can only get to CP from my limited account. Then I am prompted to >>> enter >>> the Admin account's password. At times even trying this fails with the >>> same >>> error the first time I try to launch CP. Usually the second or third >>> time I >>> launch CP it will actually launch. >>> >>> Someone suggested I set up a new admin account and then, from that >>> account, >>> rename the original Admin account's profile so that Windows would >>> rebuild it >>> upon reboot. Well, I did manage to create a new admin account (using >>> admin >>> privileges from my limited account) but even that new admin account >>> can't >>> launch control panel. >>> >>> Interestingly, after I set up the second admin account, when I try an >>> admin >>> cp function from my limited account it does correctly show me a pop-up >>> showing me two admin users to choose for entering the admin password. >>> So it >>> does know the two users as admin accounts. >>> >>> I am at a loss as to what to do/try. Is there a way to repair the OS >>> using >>> the original DVD (I didn't see any applicable repair options) >>> >>> Any help is appreciated. >>> Thanks, >>> Walter >>> >>> |
| Admin account can't access control panel? | Vista security | |||
| Admin accounts can't access control panel - please help! | Vista performance & maintenance | |||
| Admin accounts can't access control panel - please help! | Vista account administration | |||
| Admin accounts can't access control panel - please help! | Vista installation & setup | |||
| Admin account can't access control panel? | General Discussion | |||
