When I attempt to transfer programs that I have used forever on XP, Vista
erases them. How can I turn off auto protect?
Your question needs clarification. What do you mean? You cannot transfer
programs. You must reinstall from the original installation disks. What do
you mean by Auto protect erases them? Vista doesn't have autoprotect. Norton
does.
haybaywoody,
Vista is not erasing your programs. Vista does not have "autoprotect".
Autoprotect is an application embedded in some Norton products.
Do yourself a favor and uninstall Norton from your system. It is
nothing but a resource hog and causes more problems than it solves. By the
way, good luck in getting everything Norton off your system.
If you are a staunch defender of Norton products for the home user, and
don't wish to remove it, that is your decision to make. However, sooner or
later your Norton software will bite you in the ass and you may have to
reinstall your system.
Have a nice day.
C.B.
>>> By the way, good luck in getting everything Norton off your system.<<<
http://service1.symantec.com/SUPPORT...05033108162039
All the best,
SG
"CB" <CB@xxxxxx> wrote in message
news:BC97E0EF-4813-4377-9661-9D5438B109AC@xxxxxx
> haybaywoody,
> and
> Have a nice day.
> C.B.
CB wrote:If you remove Norton, you can try these programs for a free antivirus
> haybaywoody,
> Have a nice day.
> C.B.
solution:
AVG (http://free.grisoft.com/doc/2/)
Avast (http://www.avast.com/eng/avast_4_home.html)
Cheers
| Similar Threads | ||||
| memory flash stick | andrew | Vista hardware & devices | 4 | 12 Feb 2008 |
| Transfer Photoes from another PC by using flash-stick | Andre Da Costa[ActiveWin] | Vista General | 3 | 16 Dec 2007 |
| USB Memory Stick & Flash Drive | Richard Coutts | Vista General | 1 | 05 Jul 2007 |
| Error installing USB Memory stick or compact flash card | =?Utf-8?B?Q2hyaXM=?= | Vista hardware & devices | 0 | 25 Sep 2006 |
| USB-FLASH-STICK AND MP3-PLAYER | =?Utf-8?B?UEVURVIgU0FDSFNF?= | Vista General | 2 | 21 Sep 2006 |
