| | Wireless Connection Anyone experience problems with wireless connection where it shows me as connected with a good signal but nothing can connect to the internet. Also the internet map shows as internet connection is connected but the browser or any other application can't connect not sure as why this happens. If there is a work around for this would appreciate it. Thanks |
| | Re: Wireless Connection David Costelloe wrote: > Anyone experience problems with wireless connection where it shows me as > connected with a good signal but nothing can connect to the internet. > Also the internet map shows as internet connection is connected but the > browser or any other application can't connect not sure as why this > happens. > > If there is a work around for this would appreciate it. > > Thanks I had problems with this in build 5342, but OK again in 5365. May be dependent on your specific drivers. |
| | Re: Wireless Connection Same here, no problems in 5365, but I did get that in 5342. Scøtt Live Messenger FAQs - http://wlm.scottisafool.co.uk/ Mike Williams wrote: > David Costelloe wrote: >> Anyone experience problems with wireless connection where it shows me >> as connected with a good signal but nothing can connect to the >> internet. Also the internet map shows as internet connection is >> connected but the browser or any other application can't connect not >> sure as why this happens. >> >> If there is a work around for this would appreciate it. >> >> Thanks > > I had problems with this in build 5342, but OK again in 5365. May be > dependent on your specific drivers. |
| | Re: Wireless Connection I had this, i removed anything todo with IPV6, it then worked. I also remove other bit that i dident need, so i just had the very basic network stack. "David Costelloe" <davidcostelloe@sympatico.ca> wrote in message news:C7274893-4C3D-4A3D-9680-9B9E13EB55EE@microsoft.com... > Anyone experience problems with wireless connection where it shows me as > connected with a good signal but nothing can connect to the internet. Also > the internet map shows as internet connection is connected but the browser > or any other application can't connect not sure as why this happens. > > If there is a work around for this would appreciate it. > > Thanks > |
| | Re: Wireless Connection Yeh, it's a bit of a tricky one at times. I actually brought a desktop shortcut to the good ol' Windows XP networking instead to help me out with tweaking settings: http://www.vistabase.co.uk/welcome.p...xpstylenetwork - shows you how )-- Zack Whittaker » ZackNET Enterprises: www.zacknet.co.uk » MSBlog on ResDev: www.msblog.org » Vista Knowledge Base: www.vistabase.co.uk » This mailing is provided "as is" with no warranties, and confers no rights. All opinions expressed are those of myself unless stated so, and not of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared that up! --: Original message follows :-- "steve" <steve@_NOS_Drakey.co.uk> wrote in message news:uHzGGXebGHA.3380@TK2MSFTNGP04.phx.gbl... >I had this, i removed anything todo with IPV6, it then worked. > > I also remove other bit that i dident need, so i just had the very basic > network stack. > > > "David Costelloe" <davidcostelloe@sympatico.ca> wrote in message > news:C7274893-4C3D-4A3D-9680-9B9E13EB55EE@microsoft.com... >> Anyone experience problems with wireless connection where it shows me as >> connected with a good signal but nothing can connect to the internet. >> Also >> the internet map shows as internet connection is connected but the >> browser >> or any other application can't connect not sure as why this happens. >> >> If there is a work around for this would appreciate it. >> >> Thanks >> > > |
| Cannot find wireless networks/Cannot enable wireless connection | Network & Sharing | |||
| Wireless connection works, cable connection does not! | Vista General | |||
| Unable to keep wireless connection on two USB wireless cards | Network & Sharing | |||
| Losing wireless connection to specific wireless network | Vista networking & sharing | |||
| Blackberry Dialup connection interupts wireless connection | Vista networking & sharing | |||
