| | Lexmark all in one problems I need a little assistance please. I need to get my computer to communicate with my printer, however, since my install of vista beta 2 I cannot. I have tried everything offered under the printer/faxes... whatever site. No help. Lexmark has no answer as to date on their website. Am I just printerless until someone gets off their duffs and comes up with an upgrade? Please let me know and do not reply in computer code. Some of us are just normal people that live ordinary lives and cannot undrstand the computer jibberish that you intellectually superior computer gurus speak! LOL Thanks! |
| | Re: Lexmark all in one problems Until Lexmark provide the proper Vista drivers for the device, you're out of luck. Sorry. -- Jane, not plain 64bit enabled ![]() Batteries not included. Braincell on vacation ![]() "4evrnella" <4evrnella@discussions.microsoft.com> wrote in message news:0B0FD84F-CAE6-4C11-9AE8-8A0F17C64CEF@microsoft.com... >I need a little assistance please. I need to get my computer to communicate > with my printer, however, since my install of vista beta 2 I cannot. I > have > tried everything offered under the printer/faxes... whatever site. No > help. > Lexmark has no answer as to date on their website. Am I just printerless > until someone gets off their duffs and comes up with an upgrade? Please > let > me know and do not reply in computer code. Some of us are just normal > people > that live ordinary lives and cannot undrstand the computer jibberish that > you > intellectually superior computer gurus speak! LOL Thanks! |
| | Re: Lexmark all in one problems--Try this. 4evrnella-- See if this helps: 1) Most printer drivers will work in Vista by Beta 2 or beyond and several builyou go to the ds earlier. 2) Unplug the Lexmark USB from the PC; replug it and reboot and get it recognized in the notification area. Vista should give you that round logo telling you new hardware is found. Vista is better than XP at recognizing new hardware. Get the new hardware recognized before you go after getting the driver installed. 3) Then download the newest driver appropriate to your Lexmark from the Lexmark site. 4) You will get some kind of wizard up, and I strongly recommend that you choose to browse to the location where Lexmark has put that printer driver folder--it works better in Vista to do that with some drivers. It can be the difference of getting them in or not. 5) If you have the driver installed, then in the printer folder you should have the Lexmark printer. 6) Rt. click the printer and make it the default printer. 5) Open the printer folder> right click the Lexmark printer>clickthe ports tab and make sure that you have USB2 Virtual port checked. In early builds of Vista they were defaulting LPT1 but USB2 should be checked and probably is. 6) Then in the printer folder click on your Accessories tab. Under "Paper Source Setting" Highlight Tray 1 >paper size (letter)>default source is tray 1>click update then Under "Paper Source Setting">paper size (undefined)>default source is manual Tray> click update (which will let you load envelops, other sizes of labels). Good luck, CH "4evrnella" <4evrnella@discussions.microsoft.com> wrote in message news:0B0FD84F-CAE6-4C11-9AE8-8A0F17C64CEF@microsoft.com... >I need a little assistance please. I need to get my computer to communicate > with my printer, however, since my install of vista beta 2 I cannot. I > have > tried everything offered under the printer/faxes... whatever site. No > help. > Lexmark has no answer as to date on their website. Am I just printerless > until someone gets off their duffs and comes up with an upgrade? Please > let > me know and do not reply in computer code. Some of us are just normal > people > that live ordinary lives and cannot undrstand the computer jibberish that > you > intellectually superior computer gurus speak! LOL Thanks! |
| Spooler Subsytem App problems reinstalling Lexmark | Vista print fax & scan | |||
| Spooler Subsystem problems reinstalling Lexmark | Vista print fax & scan | |||
| Spooler SubSystem problems reinstalling Lexmark | Vista print fax & scan | |||
| Problems with Lexmark X4530 Wireless printer | Vista print fax & scan | |||
| Lexmark 1270 problems | Vista print fax & scan | |||
