| | Notification area/ How to get rid of Caps Lock, Scroll Lock Can some tell me how to get rid of the Caps Lock, Scroll Lock, & Numbers Lock off of the Notification area? |
| | Re: Notification area/ How to get rid of Caps Lock, Scroll Lock "Heidi" <Heidi@xxxxxx> wrote in message news:6484C9B1-D5E3-4FB1-B61A-C22E13E67090@xxxxxx Quote: > Can some tell me how to get rid of the Caps Lock, Scroll Lock, & Numbers > Lock > off of the Notification area? added by some keyboard software from your laptop manufacturer. ss. |
| | Re: Notification area/ How to get rid of Caps Lock, Scroll Lock On Thu, 31 Jan 2008 15:34:01 -0800, Heidi wrote: Quote: > Can some tell me how to get rid of the Caps Lock, Scroll Lock, & Numbers Lock > off of the Notification area? |
| | Re: Notification area/ How to get rid of Caps Lock, Scroll Lock No it is not a laptop. Also I have all kinds of problems.....lol. Is there anyway to completely remove and reinstall windows vista? Or if I buy the upgraded version will it use any of the exsiting features from the home basic version? Thanks "Synapse Syndrome" wrote: Quote: > "Heidi" <Heidi@xxxxxx> wrote in message > news:6484C9B1-D5E3-4FB1-B61A-C22E13E67090@xxxxxx Quote: > > Can some tell me how to get rid of the Caps Lock, Scroll Lock, & Numbers > > Lock > > off of the Notification area? > It's not there by default. Are you using a laptop? It is most probably > added by some keyboard software from your laptop manufacturer. > > ss. > > > |
| | Re: Notification area/ How to get rid of Caps Lock, Scroll Lock "Heidi" <Heidi@xxxxxx> wrote in message news:B1439B76-6C88-415F-A27B-27451CE3D213@xxxxxx Quote: > No it is not a laptop. Also I have all kinds of problems.....lol. Is > there > anyway to completely remove and reinstall windows vista? Or if I buy the > upgraded version will it use any of the exsiting features from the home > basic > version? make a new post asking people about this. ss. |
| | #6 (permalink) |
| Vista Business X64 and Ultimate X64 two machines | Re: Notification area/ How to get rid of Caps Lock, Scroll Lock Just fixed this on a customer's machine. It is a program that is installed by default in the initial factory setup from HP. Go to Control Panel, then Programs and Features. It will be listed as a program that can be uninstalled. It is not possible to right click and delete the icon as previous posts suggest. |
| | #7 (permalink) |
| Vista Premium | Re: Notification area/ How to get rid of Caps Lock, Scroll Lock You cannot right click on those. They have to be removed internally. Here's how ya do it. Start (bottom left corner) --> Control Panel --> Programs --> Programs and Features --> Scroll down till you see a file with this title.... HP On-Screen Cap/ Num/ Scroll Lock Indicator Right click that little sucker and delete it! Congo Rats! |
| HP On-Screen Caps/Num/Scroll lock Indicator | Software | |||
| scroll, number, caps lock indicators | Vista General | |||
| CAPS lock / SHIFT lock difficulty | Vista General | |||
| caps/num lock | Vista installation & setup | |||
| Deleting Caps/Num/Scroll-Lock Tray icons | Vista General | |||
