| | Vista Keeps Losing Wireless WEP 128 bit Encryption Key I have a Linksys wireless n router and have 2 notebooks (XP) and one notebook (vista), all of which use wireless connections to the router. I use 128 bit WEP encryption and the 2 XP notebooks have ZERO problem. However, the Vista notebook keeps losing the encryption key and thus loses wireless connection. If I re-enter the key, the wireless connection works but some time later, the same problem happens again. What is going on? Thanks. |
| | RE: Vista Keeps Losing Wireless WEP 128 bit Encryption Key Check to see if you have a latest Network Adaptor driver Also, check to see if there is vista compatible updated firmware for your router. "KlausK" wrote: Quote: > I have a Linksys wireless n router and have 2 notebooks (XP) and one > notebook (vista), all of which use wireless connections to the router. I use > 128 bit WEP encryption and the 2 XP notebooks have ZERO problem. However, > the Vista notebook keeps losing the encryption key and thus loses wireless > connection. If I re-enter the key, the wireless connection works but some > time later, the same problem happens again. What is going on? Thanks. > > > |
| | Re: Vista Keeps Losing Wireless WEP 128 bit Encryption Key "KlausK" <dinga@xxxxxx> wrote in message news:47a2b158$0$25018$607ed4bc@xxxxxx Quote: >I have a Linksys wireless n router and have 2 notebooks (XP) and one >notebook (vista), all of which use wireless connections to the router. I >use 128 bit WEP encryption and the 2 XP notebooks have ZERO problem. >However, the Vista notebook keeps losing the encryption key and thus loses >wireless connection. If I re-enter the key, the wireless connection works >but some time later, the same problem happens again. What is going on? >Thanks. WPA. -- Paul Smith, Yeovil, UK. Microsoft MVP Windows Shell/User. http://www.dasmirnov.net/blog/ http://www.windowsresource.net/ *Remove nospam. to reply by e-mail* |
| | Re: Vista Keeps Losing Wireless WEP 128 bit Encryption Key Have you got your ssid broadcasting?if not you could try turning that on..Saying that,the advice you have been given so far drivers f/ware etc. are also considerations,for myself I would 1st turn the ssid on with vista to see if this works. Regards, knobber "KlausK" <dinga@xxxxxx> wrote in message news:47a2b158$0$25018$607ed4bc@xxxxxx Quote: >I have a Linksys wireless n router and have 2 notebooks (XP) and one >notebook (vista), all of which use wireless connections to the router. I >use 128 bit WEP encryption and the 2 XP notebooks have ZERO problem. >However, the Vista notebook keeps losing the encryption key and thus loses >wireless connection. If I re-enter the key, the wireless connection works >but some time later, the same problem happens again. What is going on? >Thanks. > |
| Losing wireless connection to specific wireless network | Vista networking & sharing | |||
| Answers to wireless encryption | Vista General | |||
| Losing wireless connection | Vista print fax & scan | |||
| Losing wireless connectivity | Vista networking & sharing | |||
| Losing the static IP address on a wireless card with Vista | Vista networking & sharing | |||
