Vista - Control Panel Goes Missing
Old 02-05-2008   #1 (permalink)
Woodbine
My Control Panel on Vista Home Premium has gone missing together with the
Windows Update.
Just a brief flash of an opening and closing window.
I've had a search around on Google on this subject and found only one
solution which, sadly, lasts until the next reboot.
This is to....
) Launch services.msc from a run command
2) Find the SLU Notify service & stop it
3) Find the Software Licensing service & stop it (it may say that
ReadyBoost needs that service to run; stop it anyway)
4) Restart both services, starting with Software Licensing
Does anyone have a more permanent fix?
This is a Dell XPS 420
Old 02-05-2008   #2 (permalink)
Woodbine
Re: Control Panel Goes Missing
On Tue, 05 Feb 2008 21:41:55 +0000, Woodbine wrote:
> the Windows Update.
> Just a brief flash of an opening and closing window. I've had a search
> around on Google on this subject and found only one solution which,
> sadly, lasts until the next reboot. This is to....
> ) Launch services.msc from a run command 2) Find the SLU Notify service
> & stop it 3) Find the Software Licensing service & stop it (it may say
> that ReadyBoost needs that service to run; stop it anyway) 4) Restart
Bad form to follow up on ones own post but I see that since I searched
earlier someone else has a similar problem posted in a thread below this
one.
I indeed found the Microsoft Fix suggested by MICHAEL but thought it
referred to a problem with Nero as in
"error message during Windows Vista startup if the Nero InCD program is
installed and if the "Special pool" feature is enabled in the Driver
Verifier utility: "Stop 00000050""
I will try the fix.
Old 02-05-2008   #3 (permalink)
MICHAEL
"Woodbine" <woodbine@xxxxxx> wrote in message news:foaln8$oo5$2@xxxxxx
>> the Windows Update.
> one.
> I will try the fix.
Please post back to let us know if the hotfix worked
for you. Hopefully, it does.
-Michael
Old 02-06-2008   #4 (permalink)
Woodbine
>>> the Windows Update.
>>> sadly, lasts until the next reboot. This is to.... ) Launch
>>> services.msc from a run command 2) Find the SLU Notify service & stop
>>> it 3) Find the Software Licensing service & stop it (it may say that
>>> ReadyBoost needs that service to run; stop it anyway) 4) Restart both
>> this one.
>> referred to a problem with Nero as in "error message during Windows
>> Vista startup if the Nero InCD program is installed and if the "Special
>> pool" feature is enabled in the Driver Verifier utility: "Stop
>> 00000050""
>> I will try the fix.
> Please post back to let us know if the hotfix worked for you.
> Hopefully, it does.
> -Michael
I booted Vista this morning and as luck would have it, the control panel
worked OK.
I have just run the fix and if all is OK in a few days, I'll post back.
Thanks for the advice.
Control panel applet missing Vista General
missing items at control panel General Discussion
Control panel and all functions go missing Vista General
Control Panel Home Is Missing Vista file management
Missing Control Panel Text Vista General
