Vista - Vista SATA II Hard Drive Installation Problem
Old 02-06-2008   #1 (permalink)
Drew30
Hi:
I cannot add a new internal SATA drive in Vista (extra storage or
"slave" in the old nomenclature) with proper physical installation.
BIOS finds it. Device Manager sees it (Properly labeled) under "other
devices."
Have purchased second Hard Drive ("works with Vista") with same
result.
Exasperated from long calls to HD support and messing around on my
own.
Machine is Gateway, HD is Seagate all products are less than two weeks
old.
Any lifelines?
Much Appreciated,
Andrew
Drew30
Drew30's Profile: http://forums.techarena.in/member.php?userid=41189
View this thread: http://forums.techarena.in/showthread.php?t=909496
Old 02-06-2008   #2 (permalink)
R. McCarty
Re: Vista SATA II Hard Drive Installation Problem
Device Manager entry for the drive shouldn't be in the other devices
category. Does it appear in DiskMgmt.Msc ?
"Drew30" <Drew30.34dr3c@xxxxxx> wrote in message
newsrew30.34dr3c@xxxxxx
Quote:
> Hi:
> devices."
> result.
> own.
> old.
> Any lifelines?
> Much Appreciated,
> Andrew
> Drew30
Old 02-06-2008   #3 (permalink)
Drew30
is DiskMgmt.Msc a DOS file?
Thanks for the reply.
I am presently away from this machine, but 90 minutes from now I will
look for this file.
Drew30
Old 02-06-2008   #4 (permalink)
Len
Right click "Computer" either on desktop if you chose to put it there or on
the right side of the start menu. Go down to where it says "Manage" and
left click on that. Once the management console is open on the right side
of the window down towards the bottom you will see "Disk Management". Left
click on that and it will open DiskMgmt.msc.
Good Luck,
Len
"Drew30" <Drew30.34dwne@xxxxxx> wrote in message
newsrew30.34dwne@xxxxxx
> look for this file.
> Drew30
Old 02-07-2008   #5 (permalink)
Brian W
> look for this file.
Also check if there are any driver updates for the disk controller
Old 02-14-2008   #6 (permalink)
fade2gray
Drew30 said...
In the Start Menu search field, type DiskMgmt.Msc (can also be found in
Control Panel / Maintenance / Administrative Tools).
I had a similar problem with my old XP machine where Windows didn't see
a new sata hd. If you have the option to in the bios, try setting it as
a RAID device - it worked for me.
fade2gray
Old 03-12-2008   #7 (permalink)
Steve
The Fix
Drew,
Here is the fix. Go to start>run. Type in DiskMgmt.Msc then click OK.
A window will pop up and you will see your new drive and it says
unallocated. It will probably be listed as disk 1. Right click where it
says Disk 1(if that is the unallocated drive.) Click initialize. after that
is done, right click in the area that said/says unallocated and select simple
volume, the pop up box will walk you through the rest. good Luck.
"Drew30" wrote:
Quote:
> Hi:
> devices."
> result.
> own.
> old.
> Any lifelines?
> Much Appreciated,
> Andrew
> Drew30
Old 03-12-2008   #8 (permalink)
kurttrail
Re: The Fix
Steve wrote:
Quote:
> Drew,
> Here is the fix. Go to start>run. Type in DiskMgmt.Msc then click OK. A
> it says Disk 1(if that is the unallocated drive.) Click initialize.
> after that is done, right click in the area that said/says unallocated
> and select simple volume, the pop up box will walk you through the rest.
> good Luck.
He'll need luck to find your reply outside of the thread you should have
been replying to.
Peace!
Kurt
Former Self-anointed Moderator
microscum.pubic.windowsexp.gonorrhea
"Produkt-Aktivierung macht frei!"
My sata hard drive does not appear in Vista Vista General
Vista Will NOT Recognize 2nd SATA Hard Drive! Vista hardware & devices
Can't see SATA XP Hard drive with in Vista 64bit Vista hardware & devices
SATA Drive & Vista Installation Vista General
Problem with hard drive sata detection vista Vista hardware & devices
