1.    08 Feb 2008 #1
    David F Guest
    Problem running 6TO4 Adapter driver
    I've had a yellow triangle for awhile on the 6TO4 adapter driver for Vista
    Business 64:
    "This device is not working properly because Windows cannot load the drivers
    required for this device. (Code 31)"
    I tried to do a driver update and I have the most up-to-date driver. I
    couldn't find anything in the event viewer and when I tried to report the
    problem to Msft I didn't get any fix solution.
    Any ideas? TIA.
  2.    08 Feb 2008 #2
    Carlos Guest
    RE: Problem running 6TO4 Adapter driver
    David,
    It seems that you are having problems with your current driver for your
    network card or chipset.
    Best place to start would be your PC or laptop manufacturer web site and
    check there for updated driver, forums, faqs.
    Second place would be the card or chipset manufacturer.
    I never use MSFT hardware drivers unless I cannot pinpoint its original
    manufacturer.
    Here is an example of the workarounds that some people have experienced:
    http://www.annoyances.org/exec/forum...ta/t1190414616
    Carlos
    > Business 64:
    > Any ideas? TIA.
  3.    10 Feb 2008 #3
    David F Guest
    Re: Problem running 6TO4 Adapter driver
    Carlos,
    Thanks! David
    "Carlos" <Carlos@xxxxxx> wrote in message
    news:17C91646-C571-451A-BE1D-8F847F2662BD@xxxxxx
    > David,
    > manufacturer.
    > Carlos
    >> Vista
    >> Business 64:
    >> drivers
    >> Any ideas? TIA.
  4.    10 Feb 2008 #4
    David F Guest
    Here is the Msft official writeup:
    http://forums.microsoft.com/TechNet/...6928&SiteID=17
    "David F" <dfumento@xxxxxx> wrote in message
    news:2E6F7A73-8252-499C-826F-AEA01A0474D7@xxxxxx
    > Carlos,
    > Thanks! David
    >> David,
    >> manufacturer.
    >> Carlos
    >>> Vista
    >>> Business 64:
    >>> drivers
    >>> the
    >>> Any ideas? TIA.
Microsoft adapter 6to4
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)..Is there any way I can fix this?
Drivers
Microsoft 6to4 adapter problem and other problems
Hi I have gone into my device manager and found that under network adapters Microsoft 6 to 4 adapter has a yellow triangle beside it how do I...
Vista installation & setup
microsoft 6to4 adapter
without the microsoft 6to4 adapter can you still browse using the both wireless and Local area networks. if you can then i have a problem 'cause I...
Drivers
The Microsoft 6to4 adapter showed in the device manager that it was not working properly. If you look at yours it may show the same. I think I...
Network & Sharing
6TO4 Adapter
Here is an odd problem. Ever since I have had my laptop (which came with Vista Home Premium installed) device manager shows under Network adapters...
Vista General
6to4 adapter
does anyone know what the "6TO4 adapter" is? it has never worked, i have always received this message: "This device is not working properly...
Vista hardware & devices
network 6to4 adapter code 10 problem
i cannot connect to the internet and the cause of this has been pinpointed to the network 6to4 adapter. all of the drivers are up to date but i keep...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
