| | Setting up wireless printing... i just added my desktop computer's network to my laptop (it said added successfully) then it said to connect select from list... however it is'nt on the list... does any one know what going on and how i can connect to the network?? ps i have tried all of those how to things that people suggest but none of those work... |
| | Re: Setting up wireless printing... Without any quotes from previous posts, we can't tell what you have tried. If you search the MS KB (www.support.microsoft.com) , there is a network discovery download that will help Vista see XP machines (it is installed on the XP machine not the Vista one). If you have set the router to assign an address automatically and use the same workgroup name, and have file/print sharing enabled and at least 1 file/folder shared; it should show on the network. If you have a wireless network, you may need to have the router either broadcast the SSID or know what it is to search for it on the wireless connection list. You also may have security software, firewall, Norton, Mcafee or such blocking your access. Without the details, general information is all that can be offered. "Josh_b" <Joshb@xxxxxx> wrote in message news:8D7A855A-BEE6-4264-A41F-8006968D5C0B@xxxxxx Quote: >i just added my desktop computer's network to my laptop (it said added > successfully) then it said to connect select from list... however it is'nt > on > the list... does any one know what going on and how i can connect to the > network?? ps i have tried all of those how to things that people suggest > but > none of those work... > |
| | Re: Setting up wireless printing... "Josh_b" <Joshb@xxxxxx> schreef in bericht news:8D7A855A-BEE6-4264-A41F-8006968D5C0B@xxxxxx Quote: >i just added my desktop computer's network to my laptop (it said added > successfully) then it said to connect select from list... however it is'nt > on > the list... does any one know what going on and how i can connect to the > network?? ps i have tried all of those how to things that people suggest > but > none of those work... > Supposing you everthing according to the rules i had the same problem. I have no explanation for it but after creating a new port for the networkprinter it was working fine. The setting were identical and after a restall i had the same problem. A trial worth. Up till know i am looking forward to the reason on it. Succes Huib |
| | Re: Setting up wireless printing... Check your firewall settings as this is the thing that usually screws me up. There is also an option somewhere to turn network discovery on in the network and sharing center - that’s the other thing the fouled me up when I tried to connect 2 vista laptops to my XP desktop network. As far as printer goes, I found what worked the best for me was attaching the printer directly to the vista laptop and installing it first, then I connected the printer back to the desktop computer and the vista laptop found the drivers for it when it kept crashing the print spooler otherwise. Lori -- Shop for clothes, boots, gothic, jewelry, collectible, Egyptian and more! LAB Enterprises - orders@xxxxxx Read our blog with links to all our stores at www.Labeshops.com "Josh_b" <Joshb@xxxxxx> wrote in message news:8D7A855A-BEE6-4264-A41F-8006968D5C0B@xxxxxx Quote: > i just added my desktop computer's network to my laptop (it said added > successfully) then it said to connect select from list... however it is'nt > on > the list... does any one know what going on and how i can connect to the > network?? ps i have tried all of those how to things that people suggest > but > none of those work... > |
| | RE: Setting up wireless printing... http://technet.microsoft.com/en-us/l.../bb727037.aspx Have a read of the above link re Vista File and Printer Sharing. How to give Permissions are there, too. If you are running Norton, Trend Micro, McAfee, etc’s Firewall, check its settings to make sure it allows file and printer sharing.. 1st thing to do is make sure that the Workgroup Name of ALL the computers is the SAME. In Vista Network and Sharing: Network Discovery: ON (So it can see the other computers) Network set to Private (Public is for hotspots, airports, etc) File Sharing: ON Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared Docs) Password Protected: OFF (unless you want to set up identical usernames and passwords on ALL computers in your Network) If you have it ON, you will be asked for a username and password when you try to access a Vista computer from an XP computer. Also, run the XP’s Home Network File and Printer sharing Wizard. "Josh_b" wrote: Quote: > i just added my desktop computer's network to my laptop (it said added > successfully) then it said to connect select from list... however it is'nt on > the list... does any one know what going on and how i can connect to the > network?? ps i have tried all of those how to things that people suggest but > none of those work... > |
| Setting Printing Preference in Vista x64 | Vista print fax & scan | |||
| Wireless Printing | Vista networking & sharing | |||
| Wireless router; setting up my wireless network? | Vista networking & sharing | |||
| wireless printing | Vista print fax & scan | |||
| wireless printing | Vista networking & sharing | |||
