Vista - Monitor doesn't power off
Old 02-09-2008   #1 (permalink)
Peekstra
Hi everyone,
as the subject says, I have a problem with my computer: the display
doesn't turn off after the configured time set in the active power plan.
The screensaver works fine, so it's not that (for example) a mouse is
giving random input. Also, when I shut down the computer, the display
jumps to powersaving, so the display works fine.
I've already tried a lot of things to solve it and I hope that someone
can help because I don't know what to do know....
Things I've tried:
- Set a different time in the power plan, set time time to disabled and
enabled again.
- Disable all wakeon devices by using powercfg
- Install a generic monitor driver instead of the Samsun 204B one.
- Use the secondary DVI port
- Update to the latest Nvidia drivers for my 7600GT
- Run Vista with all programs disabled (both tried msconfig and
safemode)
- Use the latest BIOS for my motherboard (S3 mode is set to enabled
according to powercfg).
- Installed the latest Intel INF files
- Create a new power plan
- Tried a different screensaver
So what can I try now?
thanks!
Peekstra
Posted via http://www.vistaheads.com
Old 02-09-2008   #2 (permalink)
Mark L. Ferguson
Re: Monitor doesn't power off
Have you looked at your S3 settings in the BIOS setup configuration?
bios setup access keys. Go to:
http://michaelstevenstech.com/bios_manufacturer.htm
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"Peekstra" <Peekstra.34ixo6@xxxxxx-mx.forums.vistaheads.com> wrote in message
news:Peekstra.34ixo6@xxxxxx-mx.forums.vistaheads.com...
Quote:
> Hi everyone,
> Things I've tried:
> enabled again.
> safemode)
> thanks!
> Peekstra
Old 02-09-2008   #3 (permalink)
Peekstra
Hi Mark,
the BIOS is configured to use S3 mode, and there are no monitor related
settings (gigabyte ds3).
However, I think that these settings are only relevant in sleep mode.
thanks.
Peekstra
How do i prevent monitor power off... General Discussion
Monitor doesn't power off General Discussion
Vista and Monitor Power Saving Vista hardware & devices
Can't power down monitor Vista General
Monitor will not go into Power Save - 5472 Vista General
