| | Vista - Need help with display driver error |
| 02-09-2008 | #1 |
| | Need help with display driver error Vista Home premium with all updates and ATI Radeon 1900 with the latest drivers Good afternoon, I am trying to install a second LCD monitor and both monitors are connected to the DVI ports on the card. When I try to change settings on the monitors I get the following error: "The currently selected display driver can not be used. It was written for a previous version of Windows, and is no longer compatible with this version of Windows. The system has been started using the default VGA driver" I have the latest ATI driver/software installed (8.1) plus I tried uninstalling the driver, cleaning with Driver Cleaner Pro and reinstalling however the error remains. In the catalyst control panel there is nothing I can change to help with this issue. Any suggestions on how to deal with this problem I will be grateful for Thanks |
| My System Specs |
| Similar Threads for: Need help with display driver error | ||||
Display Driver Has Stopped Responding Error | Drivers | |||
| Error: Display Driver R300 stopped responding | Vista General | |||
| Igfx display driver error | Vista Games | |||
| display driver error HELP!! | Drivers | |||
