| | I need help Bad with VISTA Home Premium 64 As you can see below in my signature, this is a pretty strong system. I also have 3 SATA WD Cavier SE16 250 gb SATA hard drives. Now that being said I cannot get VISTA to load on anything but an IDE hard drive I have left over from an older sytem, only 30 GB. After the initial loading of the temp software, (on SATA or SATA RAID) I get a message that the driver is missing for the DVD/CD drive (SATA) and to install it. Well, no matter what I try it will not find a driver. So I go into the bios and I switch it from RAID to regular SATA -AHCI. Now the BIOS sees the drives, but the OS does not. I try to load the drivers and I keep getting nothing. All the drivers show as not compatible with VISTA. I have tried everything I can think of, every BIOS setting and all kinds of drivers and downloads. Please help me, I am not dumb, I use to do this for a living and never had this mush trouble out of an OS. I think I will go back to Win XP 64. -- Ed Smith AMD Phenom 9500 2.2 GB AM2 65N R Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N SATA DVD Burner, Power Color 2600XT Video Win Vista 64 Bit Home Premium 400W |
| | RE: I need help Bad with VISTA Home Premium 64 Go the the hard drive manufact's,and download the SATA drive for it. Put it on a Mem stick, and with your setup, try installing on just one SATA drive. When you install, it will prompt you for the driver for the HDD "Ed" wrote: Quote: > As you can see below in my signature, this is a pretty strong system. I also > have 3 SATA WD Cavier SE16 250 gb SATA hard drives. Now that being said I > cannot get VISTA to load on anything but an IDE hard drive I have left over > from an older sytem, only 30 GB. After the initial loading of the temp > software, (on SATA or SATA RAID) I get a message that the driver is missing > for the DVD/CD drive (SATA) and to install it. Well, no matter what I try it > will not find a driver. So I go into the bios and I switch it from RAID to > regular SATA -AHCI. Now the BIOS sees the drives, but the OS does not. I > try to load the drivers and I keep getting nothing. All the drivers show as > not compatible with VISTA. I have tried everything I can think of, every > BIOS setting and all kinds of drivers and downloads. Please help me, I am > not dumb, I use to do this for a living and never had this mush trouble out > of an OS. I think I will go back to Win XP 64. > -- > Ed Smith > AMD Phenom 9500 2.2 GB AM2 65N R > Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N > SATA DVD Burner, Power Color 2600XT Video > Win Vista 64 Bit Home Premium > 400W |
| | Re: I need help Bad with VISTA Home Premium 64 From your signature it looks like you are running with less than 4 Gigs of RAM. One of the reasons to use a 64-bit OS is so that you can use 4 Gigs of RAM or more. While the 64-bit OS in itself doesn't have issues, there are compatibility issues with software programs and drivers. Using it will risk such issues - and if you don't have the hardware that it takes advantage of, why bother? "Ed" <Ed@xxxxxx> wrote in message news:3C86CC09-5C4B-4FB8-97A0-08ED2927F22A@xxxxxx Quote: > As you can see below in my signature, this is a pretty strong system. I > also > have 3 SATA WD Cavier SE16 250 gb SATA hard drives. Now that being said I > cannot get VISTA to load on anything but an IDE hard drive I have left > over > from an older sytem, only 30 GB. After the initial loading of the temp > software, (on SATA or SATA RAID) I get a message that the driver is > missing > for the DVD/CD drive (SATA) and to install it. Well, no matter what I try > it > will not find a driver. So I go into the bios and I switch it from RAID to > regular SATA -AHCI. Now the BIOS sees the drives, but the OS does not. I > try to load the drivers and I keep getting nothing. All the drivers show > as > not compatible with VISTA. I have tried everything I can think of, every > BIOS setting and all kinds of drivers and downloads. Please help me, I am > not dumb, I use to do this for a living and never had this mush trouble > out > of an OS. I think I will go back to Win XP 64. > -- > Ed Smith > AMD Phenom 9500 2.2 GB AM2 65N R > Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N > SATA DVD Burner, Power Color 2600XT Video > Win Vista 64 Bit Home Premium > 400W |
| | RE: I need help Bad with VISTA Home Premium 64 OK, I will try that before I call Microsoft, Thanks. And Boy you guys are rough. Ed -- Ed Smith AMD Phenom 9500 2.2 GB AM2 65N R Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N SATA DVD Burner, Power Color 2600XT Video Win Vista 64 Bit Home Premium 400W "Mick Murphy" wrote: Quote: > Go the the hard drive manufact's,and download the SATA drive for it. > Put it on a Mem stick, and with your setup, try installing on just one SATA > drive. > When you install, it will prompt you for the driver for the HDD > > "Ed" wrote: > Quote: > > As you can see below in my signature, this is a pretty strong system. I also > > have 3 SATA WD Cavier SE16 250 gb SATA hard drives. Now that being said I > > cannot get VISTA to load on anything but an IDE hard drive I have left over > > from an older sytem, only 30 GB. After the initial loading of the temp > > software, (on SATA or SATA RAID) I get a message that the driver is missing > > for the DVD/CD drive (SATA) and to install it. Well, no matter what I try it > > will not find a driver. So I go into the bios and I switch it from RAID to > > regular SATA -AHCI. Now the BIOS sees the drives, but the OS does not. I > > try to load the drivers and I keep getting nothing. All the drivers show as > > not compatible with VISTA. I have tried everything I can think of, every > > BIOS setting and all kinds of drivers and downloads. Please help me, I am > > not dumb, I use to do this for a living and never had this mush trouble out > > of an OS. I think I will go back to Win XP 64. > > -- > > Ed Smith > > AMD Phenom 9500 2.2 GB AM2 65N R > > Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N > > SATA DVD Burner, Power Color 2600XT Video > > Win Vista 64 Bit Home Premium > > 400W |
| | Re: I need help Bad with VISTA Home Premium 64 Well other than you all coming here to bust on each other no one helped me a bit. I understand about the memory but that has nothing to do with what is going on. -- Ed Smith AMD Phenom 9500 2.2 GB AM2 65N R Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N SATA DVD Burner, Power Color 2600XT Video Win Vista 64 Bit Home Premium 400W "Xenomorph" wrote: Quote: > From your signature it looks like you are running with less than 4 Gigs of > RAM. > > One of the reasons to use a 64-bit OS is so that you can use 4 Gigs of RAM > or more. > > While the 64-bit OS in itself doesn't have issues, there are compatibility > issues with software programs and drivers. Using it will risk such issues - > and if you don't have the hardware that it takes advantage of, why bother? > > > "Ed" <Ed@xxxxxx> wrote in message > news:3C86CC09-5C4B-4FB8-97A0-08ED2927F22A@xxxxxx Quote: > > As you can see below in my signature, this is a pretty strong system. I > > also > > have 3 SATA WD Cavier SE16 250 gb SATA hard drives. Now that being said I > > cannot get VISTA to load on anything but an IDE hard drive I have left > > over > > from an older sytem, only 30 GB. After the initial loading of the temp > > software, (on SATA or SATA RAID) I get a message that the driver is > > missing > > for the DVD/CD drive (SATA) and to install it. Well, no matter what I try > > it > > will not find a driver. So I go into the bios and I switch it from RAID to > > regular SATA -AHCI. Now the BIOS sees the drives, but the OS does not. I > > try to load the drivers and I keep getting nothing. All the drivers show > > as > > not compatible with VISTA. I have tried everything I can think of, every > > BIOS setting and all kinds of drivers and downloads. Please help me, I am > > not dumb, I use to do this for a living and never had this mush trouble > > out > > of an OS. I think I will go back to Win XP 64. > > -- > > Ed Smith > > AMD Phenom 9500 2.2 GB AM2 65N R > > Gigabyte Ga-Ma77DS3 MB, Kingstaon 2X1 Gig DDRII 8500 mem. Samsung SH-S203N > > SATA DVD Burner, Power Color 2600XT Video > > Win Vista 64 Bit Home Premium > > 400W |
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Updating from Home Premium to Ultimate and moving Home Premium | Vista installation & setup | |||
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | Vista General | |||
| I think I finially got my friends XP Home and Vista Home Premium machines to Share | Vista networking & sharing | |||
| Windows XP Home (Full Vers.) to Vista Home Premium Upgrade (Academ | Vista General | |||
