| | Hard drive write protected Hi all, On my vista box, my C:\ drive is protected against writes and I need to manually authorize each write. Needless to say, this is turning out into a major pain in the ass as I can't run any programs which need write access. Is this an inbuilt Vista feature? How do I disable this? Thanks, Sashi |
| | Re: Hard drive write protected The NTFS file system allow you to change access right if you 'run as admin'. You receive an error message when you try to save a file to a hard disk drive or to a flash device in Windows Vista : http://support.microsoft.com/kb/931277/en-us -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Mark L. Ferguson .. "Sashi" <smalladi@xxxxxx> wrote in message news:c6057bd3-69b0-4bdb-b476-989dc62cbee6@xxxxxx Quote: > Hi all, > On my vista box, my C:\ drive is protected against writes and I need > to manually authorize each write. > Needless to say, this is turning out into a major pain in the ass as I > can't run any programs which need write access. > Is this an inbuilt Vista feature? How do I disable this? > Thanks, > Sashi |
| | Re: Hard drive write protected You might try this. Open an admin command prompt. Type [cd\] Press Enter. Type [attrib -r] Press Enter. "Sashi" <smalladi@xxxxxx> wrote in message news:c6057bd3-69b0-4bdb-b476-989dc62cbee6@xxxxxx Quote: > Hi all, > On my vista box, my C:\ drive is protected against writes and I need > to manually authorize each write. > Needless to say, this is turning out into a major pain in the ass as I > can't run any programs which need write access. > Is this an inbuilt Vista feature? How do I disable this? > Thanks, > Sashi |
| Hard Drive is Write Protected? | Vista General | |||
| Disk Drive is write protected or Read only | Vista General | |||
| Write-Protected Flash Drive? | Vista General | |||
| Why is my hard drive actubg as thour it is write-protected? | Vista General | |||
| USB Flash drive write protected | Vista hardware & devices | |||
