| | start up/boot problems I have a Sony Vaio computer that is awesome and it's running vista. so the problem is that when ever i hit the power button the computer sleeps which is good because i can come back to it later and everything loads up correctly. the bad part is that when ever i power down from the start menu and later, turn the computer back on the computer will do it's normal boot and the little green bars will pop up and everything looks fine however, after the little green bars go away im left with a black screen and might i add, with no curser. i look at my hard drive light and see that there is no action going on and it just sits there. what do i need to do to get windows vista to boot and load fully. thanks for your help!! jason |
| X P pro Start up/boot down Problems | .NET General | |||
| VIsta The following boot-start or system-start driver(s) failed to load: | Drivers | |||
| laptop start up problems and problems in general | General Discussion | |||
| Weirdest problems.Can't start programs from start menu and use Cop | Vista General | |||
| XP/Vista dual boot XP won't start from Vista boot manager | Vista installation & setup | |||
