Vista - Right click send to error need some help!
Old 02-12-2008   #1 (permalink)
championz
hello and thanks for looking,
i have just noticed that when i try to right click and send to, there are 3
options,
X-fire friend
DVD RW (F)
DVD RW (G)
so how do i get the other ones like Doc's, desktop, ect
thanks again for looking
Old 02-12-2008   #2 (permalink)
Mark L. Ferguson
Re: Right click send to error need some help!
Go to start/run, and type
shell:sendto
Create the file below in notepad, drag it in, and rightclick it to make it
have a hidden property.
--desktop.ini--
[LocalizedFileNames]
Mail Recipient.MAPIMail=@sendmail.dll,-4
Desktop (create shortcut).DeskLink=@sendmail.dll,-21
Compressed (zipped) Folder.ZFSendToTarget=@zipfldr.dll,-10148
Documents.mydocs=@shell32.dll,-9227
Fax Recipient.lnk=@%SystemRoot%\system32\FXSRESM.dll,-12
---end file ---cut here--
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"championz" <championz@xxxxxx> wrote in message
news:CBB3E783-64E5-4F1C-97A8-8DED967D57F0@xxxxxx
> 3
> options,
> X-fire friend
> DVD RW (F)
> DVD RW (G)
Old 02-12-2008   #3 (permalink)
championz
thanks for looking and help this work great thanks again.
"Mark L. Ferguson" wrote:
> shell:sendto
> --desktop.ini--
> interface.
> Mark L. Ferguson
> > 3
> > options,
> > X-fire friend
> > DVD RW (F)
> > DVD RW (G)
Right Click Send To Mail recipient - Send button doesnt work Vista General
When I click start, games, then click on a game I get this error message: Vista General
Send Mail with right click Vista General
Right click >> send to - donīt work? Vista General
Add to the right-click send-to Vista General
Đ Designer Media Ltd
