Vista - Problem with Win Vista 64-bit ('Thunking Spooler APIS from 32 to 6
Old 02-13-2008   #1 (permalink)
amk
I have problem regarding Windows Vista 64-bit. When I start (some
application) I received message 'Thunking Spooler APIS from 32 to 64 Process
has stopped working' and it seems that is Windows Vista 64-bit problem.
So, do you have some solution how to solve this problem?
Old 02-13-2008   #2 (permalink)
Mark L. Ferguson
Re: Problem with Win Vista 64-bit ('Thunking Spooler APIS from 32 to 6
You would need a printer driver written for 64 bits. You are using a 32 bit
driver.
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"amk" <amk@xxxxxx> wrote in message
news:E01D1356-7602-4496-AC8C-887DFA40D9DD@xxxxxx
> Process
Old 02-14-2008   #3 (permalink)
amk
"Mark L. Ferguson" wrote:
> driver.
> interface.
> Mark L. Ferguson
> > Process
Old 02-14-2008   #4 (permalink)
amk
Mark,
when I try to install some 32-bit printer driver on my other Windows Vista
computer I did not succeed and that is reason why I think that is not caused
problem. Maybe, you have some other advice for me how to solve this problem.
> driver.
> interface.
> Mark L. Ferguson
> > Process
Old 02-14-2008   #5 (permalink)
amk
Hi Mark,
I tried to install 32-bit printer driver on my other Windows Vista computer
but I did not succeed. So I thing that is not caused the problem.
Maybe, you have some other advise for me ...
> driver.
> interface.
> Mark L. Ferguson
> > Process
Old 02-14-2008   #6 (permalink)
Mark L. Ferguson
If the 32 bit driver works on another 64 bit system, you probably have a
corrupt copy of the print driver installed . I would try installing the
printer again.
interface.
Mark L. Ferguson
news:44B17102-BA37-4475-932E-83B2A6F7296D@xxxxxx
Quote:
> Hi Mark,
> computer
>> bit
>> driver.
>> interface.
>> Mark L. Ferguson
>> > Process
Thunking Spooler APIS ... stopped working Vista print fax & scan
Thunking Spooler APIS from 32 to 64 process has stopped working Vista print fax & scan
Thunking Spooler APIS 30 to 64 Vista print fax & scan
Thunking spooler APIS from 32 to 64 Vista hardware & devices
Thunking Spooler APIS Vista print fax & scan
