Vista Tutorial - Deleting System files problem
Old 02-13-2008   #1 (permalink)
bilvihur
Guest
I backed up my System files (Program, Users, etc) to a Backup folder when I
had to do a Partial reinstall. Now I want to delete the Backup folder. I've
run Takeown and Icals as suggested by other posts, and they completed
successfully. However, I still get permission denied when I try to delete the
folder. Can anyone help me free up 10GB of space? Thanks.
Old 02-13-2008   #2 (permalink)
PaulB
Guest
RE: Deleting System files problem
Take ownership of the files, then delete.
Paul
Old 02-13-2008   #3 (permalink)
bilvihur
Guest
Paul, please elaborate. I thought I WAS taking ownership thru takeown...
"PaulB" wrote:
> Paul
Old 02-13-2008   #4 (permalink)
PaulB
Guest
See this POST.
http://thevistaforums.com/index.php?showtopic=13839
Paul
"bilvihur" wrote:
> "PaulB" wrote:
> > Paul
Old 02-13-2008   #5 (permalink)
PaulB
Guest
Also you could delete them from safe mode.
Paul
"bilvihur" wrote:
> "PaulB" wrote:
> > Paul
Old 02-14-2008   #6 (permalink)
Darrell Gorter[MSFT]
Guest
Hello,
The question I would have is what were the commands you used takeown.exe
and Icacl.exe?
You may need to check what the permissions are on the files and folders.
You may want to run icacls c:\Backup_folder /T where backup_folder is the
name of the folder you have the files in.
This should show all the permissions. You may need to check for any files
or folders which do not have administrators with (F) Full permission on
them. The other thing to check is for files that may the (D) deny
permission on them. Deny takes precedence and would generate Access
Denied.
Thanks,
This posting is provided "AS IS" with no warranties, and confers no rights
|> Thread-Topic: Deleting System files problem
|> thread-index: Achuegpru/O0vfuDSRCZIWkyeOdljA==
|> X-WBNR-Posting-Host: 74.73.235.115
|> From: =?Utf-8?B?YmlsdmlodXI=?= <bilvihur@xxxxxx>
|> References: <B52E487C-2434-486B-A333-A646ABB53B4A@xxxxxx>
<E62F61EA-6603-4F25-A167-022CC3BB0515@xxxxxx>
|> Subject: RE: Deleting System files problem
|> Date: Wed, 13 Feb 2008 11:53:01 -0800
|> Lines: 16
|> Message-ID: <56F76410-C528-4EE6-9AC4-1644E41438BC@xxxxxx>
|> MIME-Version: 1.0
|> Content-Type: text/plain;
|> charset="Utf-8"
|> Content-Transfer-Encoding: 7bit
|> X-Newsreader: Microsoft CDO for Windows 2000
|> Content-Class: urn:content-classes:message
|> Importance: normal
|> Priority: normal
|> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.3790.2992
|> Newsgroups: microsoft.public.windows.vista.general
|> Path: TK2MSFTNGHUB02.phx.gbl
|> Xref: TK2MSFTNGHUB02.phx.gbl
microsoft.public.windows.vista.general:252206
|> NNTP-Posting-Host: tk2msftibfm01.phx.gbl 10.40.244.149
|> X-Tomcat-NG: microsoft.public.windows.vista.general
|> > Paul
when I
folder. I've
completed
delete the
Old 02-15-2008   #7 (permalink)
bilvihur
Guest
I used takeown and icacl in the DOS window under elevated command prompt.
""Darrell Gorter[MSFT]"" wrote:
Quote:
> Hello,
> and Icacl.exe?
> Denied.
> Thanks,
> |> Lines: 16
> |> MIME-Version: 1.0
> |> charset="Utf-8"
> |> Importance: normal
> |> Priority: normal
> |> > Paul
> when I
> folder. I've
> completed
> delete the
Old 02-15-2008   #8 (permalink)
Guest
Hello,
With what switches? What was the syntax that you used?
what was the output from the line I suggested which shows the current acls
Thanks,
|> thread-index: AchwDDr9kj24WaSoTJuUSgX7K2HZPA==
<cVI0Yi1bIHA.2164@xxxxxx>
|> Date: Fri, 15 Feb 2008 11:52:01 -0800
|> Lines: 71
|> Message-ID: <F8D18940-E3E4-4086-8EF1-37F57B59745D@xxxxxx>
|> MIME-Version: 1.0
|> charset="Utf-8"
|> Importance: normal
|> Priority: normal
microsoft.public.windows.vista.general:253414
|> NNTP-Posting-Host: tk2msftsbfm01.phx.gbl 10.40.244.148
|> > Hello,
takeown.exe
|> > and Icacl.exe?
folders.
the
files
on
|> > Denied.
|> > Thanks,
rights
|> > |> Lines: 16
|> > |> MIME-Version: 1.0
|> > |> charset="Utf-8"
|> > |> Importance: normal
|> > |> Priority: normal
takeown...
|> > |> > Paul
folder
|> > when I
|> > folder. I've
|> > completed
to
|> > delete the
Problem deleting movie files Vista music pictures video
Problem Deleting Files Vista General
Another Deleting Files Problem... Vista account administration
Deleting System Volume Information Files Vista performance & maintenance
Deleting vista system files from xp Vista installation & setup
