| | Workgroup Networking issues We have a small workgroup system (mix of Vista, WinXP and Win2000 PCs) with a couple of problems: AA The Vista machines can see each other on the network, but cannot see the WinXP or Win2000 PCs. The latter can see the Vista machines but cannot access their files BB One Vista machine cannot access data from another; while attempting to connect, a log-on screen appears and asks for UID/PWD. What should one enter? I tried entering PCNAME/Administrator (where PCNAME=Machine Name) as the UID and the normal login PWD as the PWD, but that combination did not work. Any other ideas? Thanks for your help |
| | RE: Workgroup Networking issues http://technet.microsoft.com/en-us/l.../bb727037.aspx Have a read of the above link re Vista File and Printer Sharing. Permissions/Share info is there as well. If using Norton, McAfee, Trend Micro I.S., make sure file and printer sharing is enabled in THEIR firewall. 1st thing to do is make sure that the Workgroup Name of ALL the computers is the SAME. In Vista Network and Sharing: Network Discovery: ON (So it can see the other computers) Network set to Private (Public is for hotspots, airports, etc) File Sharing: ON Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared Docs) Password Protected: OFF (unless you want to set up identical usernames and passwords on ALL computers in your Network) If you have it ON, you will be asked for a username and password when you try to access a Vista computer from an XP computer. Also, run the XP’s Home Network File and Printer Sharing Wizard to include Vista in your “New” Network, even if you had an XP Network set up prior to adding a Vista computer to it. "Ganz Doof" wrote: Quote: > We have a small workgroup system (mix of Vista, WinXP and Win2000 PCs) with > a couple of problems: > > AA > The Vista machines can see each other on the network, but cannot see the > WinXP or Win2000 PCs. The latter can see the Vista machines but cannot > access their files > > BB > One Vista machine cannot access data from another; while attempting to > connect, a log-on screen appears and asks for UID/PWD. What should one > enter? I tried entering PCNAME/Administrator (where PCNAME=Machine Name) as > the UID and the normal login PWD as the PWD, but that combination did not > work. Any other ideas? > > Thanks for your help > > |
| Vista / XP workgroup networking | Vista networking & sharing | |||
| Vista <-> XP Workgroup Networking | Vista networking & sharing | |||
| Workgroup networking - Vista Business to two XP Professionals | Vista networking & sharing | |||
| Vista Home Basics supports Workgroup networking? | Vista networking & sharing | |||
