| Guest | my battery icon has gone hi my battery icon has randomly disapeared from the task bar and it is dead annoyn cos i have to go into control pannel to change the power settings is there a way to get it back on the bar please thx |
| Guest | Re: my battery icon has gone Rightclick the Start button, then Properties, Notification tab, uncheck the "Hide inactive icons" checkbox. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Mark L. Ferguson .. "tomuk" <tomuk@xxxxxx> wrote in message news:05A89A97-C010-4222-87A7-07FB3D5BD3E3@xxxxxx Quote: > hi > my battery icon has randomly disapeared from the task bar and it is dead > annoyn cos i have to go into control pannel to change the power settings > is > there a way to get it back on the bar please > thx |
| Guest | RE: my battery icon has gone Hi tomuk, Right click the start orb and select 'Properties'. Select the 'Notification Area' tab. In the section headed 'System icons', check that there is a tick in the checkbox next to 'Power'. The other three options in this section are also useful ones to display if you aren't already displaying them. They are selected in the same way as described above. Dwarf "tomuk" wrote: Quote: > hi > my battery icon has randomly disapeared from the task bar and it is dead > annoyn cos i have to go into control pannel to change the power settings is > there a way to get it back on the bar please > thx |
| Guest | Re: my battery icon has gone Reboot. "tomuk" <tomuk@xxxxxx> wrote in message news:05A89A97-C010-4222-87A7-07FB3D5BD3E3@xxxxxx Quote: > hi > my battery icon has randomly disapeared from the task bar and it is dead > annoyn cos i have to go into control pannel to change the power settings > is > there a way to get it back on the bar please > thx |
| Guest | RE: my battery icon has gone The checkbox next to "Power" won't let me check it off. Now what? "Dwarf" wrote: Quote: > Hi tomuk, > > Right click the start orb and select 'Properties'. Select the 'Notification > Area' tab. In the section headed 'System icons', check that there is a tick > in the checkbox next to 'Power'. The other three options in this section are > also useful ones to display if you aren't already displaying them. They are > selected in the same way as described above. > Dwarf > > "tomuk" wrote: > Quote: > > hi > > my battery icon has randomly disapeared from the task bar and it is dead > > annoyn cos i have to go into control pannel to change the power settings is > > there a way to get it back on the bar please > > thx |
| | #6 (permalink) |
| Member | Re: my battery icon has gone I have the same problem that Anne has.... power icon does NOT show in taskbar, it is greyed out and CANNOT be checked in TASKBAR AND START MENU PROPERTIES/NOTIFICATION AREA. I have two IDENTICAL HP laptops, vista 64bit, one works fine, other does not... I find no way to turn the power icon ON. Inactive icons are NOT hidden on either machine. |
| | #7 (permalink) |
| Member | Re: my battery icon has gone update 6/28/08 Another vote for instability in VISTA... all day yesterday I had this problem... also again this morning... greyed out.. I basically opened the registery editor, went to that area, discovered that the proper "hide" entries were not there and just shut the editor. Later, I went to see the settings...and BEHOLD... the power icon was available, I checked it and it popped up!! |
| Battery Icon Missing? | Vista General | |||
| problems with battery´s icon | Vista General | |||
| Battery Icon | Vista General | |||
| Battery Icon Flashing | Vista performance & maintenance | |||
| Lost Battery Icon | Vista General | |||
