| | Way to add 'select all' to the right click menu? Vista 64bit PC Is there a way to add 'select all' to the right click menu for use in Windows Explorer? Help appreciated - IM -- USA - Washington State, Kitsap County "Replies welcomed as a sign of good etiquette" Nostradamus 1560 |
| | Re: Way to add 'select all' to the right click menu? Why not press Ctrl+A of the keyboard? "Imageman" <Imageman@xxxxxx> wrote in message news:e7ednT4QRItleCjanZ2dnUVZ_vumnZ2d@xxxxxx Quote: > Vista 64bit PC > > > Is there a way to add 'select all' to the right click menu for use in > Windows Explorer? Help appreciated - IM > > -- > USA - Washington State, Kitsap County "Replies welcomed as a sign of > good etiquette" Nostradamus 1560 > > > |
| Windows Vista x64 Ultimate | Re: Way to add 'select all' to the right click menu?
![]() This way you don't have to right-click and click again to "Select All", as you wanted. If you don't like the checkbox solution, you can also always use the hotkey combo of <CTRL>+<A>, but I find the checkbox is quicker, as I don't have to remove my hand from the mouse. |
| | RE: Way to add 'select all' to the right click menu? Open windows Explorer>Organise >Layout>MenuBar. If you did not have the MenuBar Click on Edit> then Select All "Imageman" wrote: Quote: > Vista 64bit PC > > > Is there a way to add 'select all' to the right click menu for use in > Windows Explorer? Help appreciated - IM > > -- > USA - Washington State, Kitsap County "Replies welcomed as a sign of good > etiquette" Nostradamus 1560 > > > > |
| | Re: Way to add 'select all' to the right click menu? Victor - Thanks for the tip. I'd still like to get 'select all' in the right click menu . . . IM "Victor" <1@xxxxxx> wrote in message news:47b5ea12$1@xxxxxx-privat.org... Quote: > Why not press Ctrl+A of the keyboard? > > > > > > "Imageman" <Imageman@xxxxxx> wrote in message > news:e7ednT4QRItleCjanZ2dnUVZ_vumnZ2d@xxxxxx Quote: >> Vista 64bit PC >> >> >> Is there a way to add 'select all' to the right click menu for use in >> Windows Explorer? Help appreciated - IM >> >> -- >> USA - Washington State, Kitsap County "Replies welcomed as a sign of >> good etiquette" Nostradamus 1560 >> >> >> > |
| 'Select All' - Right click menu | Vista General | |||
| Add\restore Select All to right click menu | Vista General | |||
| windows explorer - unable in any of my folders to select all or highlight first then hold shift key and then click last file ----driving me to drink | Vista General | |||
| 'Select All' option | Vista file management | |||
| Single click to select and expand | Vista General | |||
