| Vista Home Premium 32bit | Stuck in System Recovery Options My Toshiba Satellite computer has a propblem. It workled fine yesterday, I booted off last night normally. But today it is stuck in a loop...it loads some files, does Startup repair, then ask me fro my keyboard configuration. Then it takes me to log on with my password, and goes immediately to System recovery options. I try startup repair and it does everything all over again. If i try system restore, it says there are no restore points (but there were). Don't have a backup disk, checked the memory with the diagnostic tool and found no problems. if I restart or shut down and turn on again, it goes through the same process. I t will not let me into boot options with F8. I hope someone can help me fast. I need the info there!! Danny |
| | Re: Stuck in System Recovery Options Can you get to a command prompt and run sfc /scannow? "Danny Carpenter" <Danny.Carpenter.34ucs0@xxxxxx-mx.forums.net> wrote in message news anny.Carpenter.34ucs0@xxxxxx-mx.forums.net...Quote: > > My Toshiba Satellite computer has a propblem. It workled fine > yesterday, I booted off last night normally. But today it is stuck in a > loop...it loads some files, does Startup repair, then ask me fro my > keyboard configuration. Then it takes me to log on with my password, > and goes immediately to System recovery options. I try startup repair > and it does everything all over again. If i try system restore, it says > there are no restore points (but there were). Don't have a backup disk, > checked the memory with the diagnostic tool and found no problems. if I > restart or shut down and turn on again, it goes through the same > process. I t will not let me into boot options with F8. > > I hope someone can help me fast. I need the info there!! > > Danny > > > -- > Danny Carpenter |
| How to creat recovery partition with recovery image in vista to restore the system | Vista installation & setup | |||
| System Recovery Options Not Available | Vista installation & setup | |||
| System Recovery Options | Tutorials | |||
| No operating systems in System recovery options | Vista installation & setup | |||
| stuck on recovery screen for hours | Vista installation & setup | |||
