| | power point In my computer, i have windows vista powerpoint viewer. I need to make a powerpoint, but where do i go to do this? I dont have microsoft office as a program like the other programs in order to do it. |
| | Re: power point Power Point viewer is just a viewer. To make a Power Point document/presentation, you need Power Point. It is available as a separate program I believe. In any case you must buy it and install it. -- Joseph Meehan Dia 's Muire duit "Taunya" <Taunya@xxxxxx> wrote in message news:0B05B9F6-C915-445E-988F-137E7E9285F1@xxxxxx Quote: > In my computer, i have windows vista powerpoint viewer. I need to make a > powerpoint, but where do i go to do this? I dont have microsoft office as > a > program like the other programs in order to do it. |
| | Re: power point "Taunya" <Taunya@xxxxxx> wrote in message news:0B05B9F6-C915-445E-988F-137E7E9285F1@xxxxxx Quote: > In my computer, i have windows vista powerpoint viewer. I need to make a > powerpoint, but where do i go to do this? I dont have microsoft office as > a > program like the other programs in order to do it. You can buy Power Point as a stand alone package: http://office.microsoft.com/en-us/po...t/default.aspx or you can but it bundled in the Office 2007 suite: http://office.microsoft.com/en-us/su...678741033.aspx There are various mixes of the suites that may better fit your situation. The Home and Student version is a particular good value and I think you will find it pretty complete for almost all uses. BobF. |
| | Re: power point "Taunya" <Taunya@xxxxxx> wrote in message news:0B05B9F6-C915-445E-988F-137E7E9285F1@xxxxxx Quote: > In my computer, i have windows vista powerpoint viewer. I need to make a > powerpoint, but where do i go to do this? I dont have microsoft office as > a > program like the other programs in order to do it. version. |
| | Re: power point On Sun, 17 Feb 2008 07:35:02 -0800, Taunya wrote: Quote: > In my computer, i have windows vista powerpoint viewer. I need to make a > powerpoint, but where do i go to do this? I dont have microsoft office > as a program like the other programs in order to do it. MS Office - it will import and export MS Office files. OpenOffice Impress (equivalent of powerpoint) is, IMHO, easier to use and will create files that pp users will have absolutely no problem with. I've used it to create an entire layout for a church directory with Olan Mills - they accepted it as a pp file and had zero issues. |
| | #6 (permalink) |
| | Re: power point On Sun, 17 Feb 2008 10:17:02 -0600, Kissmedeeply wrote: Quote: > "Taunya" <Taunya@xxxxxx> wrote in message > news:0B05B9F6-C915-445E-988F-137E7E9285F1@xxxxxx Quote: >> In my computer, i have windows vista powerpoint viewer. I need to make >> a powerpoint, but where do i go to do this? I dont have microsoft >> office as a >> program like the other programs in order to do it. > You could try Openoffice. It is free from Sun. They just came out with a > new version. is an Open Source offshoot. |
| | #7 (permalink) |
| | Re: power point On Sun, 17 Feb 2008 07:35:02 -0800, Taunya <Taunya@xxxxxx> wrote: Quote: > In my computer, i have windows vista powerpoint viewer. I need to make a > powerpoint, but where do i go to do this? I dont have microsoft office as a > program like the other programs in order to do it. PowerPoint Viewer, as its name implies, only lets you view PowerPoint presentations, not create them yourself. If you want to create them, you need to buy a copy of PowerPoint itself; it can be bought either by itself, or as part of Microsoft Office. Alternatively, you might want to consider an alternative program compatible with PowerPoint, such as Corel Presentations (part of the less expensive Corel WordPerfect Office) or the freeware OpenOffice. Note that such programs are generally "compatible," but never 100% compatible. However, depending on your needs, one of them might work for you. -- Ken Blake, Microsoft MVP - Windows Desktop Experience Please Reply to the Newsgroup |
| power point problem | Microsoft Office | |||
| POWER POINT | Vista mail | |||
| Power point | Vista General | |||
| Power Point Viewer | Vista General | |||
| power point | Vista mail | |||
