| | Renamin a folder problem & Games missing i have installed vista ultimate. and when i tried to rename a folder(not files) vista gives us the error "file or folder does not exist". and i also having a problem with my vista games. i don't have vista games such as sollitire,mahjong,minesweeper are missing.if i tried to install manually from enable disable programmes i don't have the games option in that. i am using a radeon 512mb vga card.i can install other 3d games and it works fine. can anyone help me in this please. |
| Windows Vista x64 Ultimate | Re: Renamin a folder problem & Games missing i have installed vista ultimate. and when i tried to rename a folder(not files) vista gives us the error "file or folder does not exist". and i also having a problem with my vista games. i don't have vista games such as sollitire,mahjong,minesweeper are missing.if i tried to install manually from enable disable programmes i don't have the games option in that. i am using a radeon 512mb vga card.i can install other 3d games and it works fine. can anyone help me in this please. To add/remove games, open "Control Panel"->"Programs and Features", then click on "Turn Windows features on or off" in the left pane. Expand the "Games" entry, then check/uncheck the appropriate games... |
| | Re: Renamin a folder problem & Games missing Install your games to the C:\ProgramData folders. The rename problem is probably caused by you setup image. Contact the maker of your system for a fix. -- Was this helpful? Then click the "Yes" Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Mark L. Ferguson .. "Ahamad Izzard" <AhamadIzzard@xxxxxx> wrote in message news:493B3AE6-44F4-4466-AADC-971E406908E7@xxxxxx Quote: >i have installed vista ultimate. and when i tried to rename a folder(not > files) vista gives us the error "file or folder does not exist". > > and i also having a problem with my vista games. > > i don't have vista games such as sollitire,mahjong,minesweeper are > missing.if i tried to install manually from enable disable programmes i > don't > have the games option in that. i am using a radeon 512mb vga card.i can > install other 3d games and it works fine. > > can anyone help me in this please. |
| Two new games Chess Titan and other one Missing from my Games Expl | Vista Games | |||
| Games missing from game explorer after moving folder | Vista Games | |||
| Games Folder Problem | General Discussion | |||
| Performance index missing in games folder | Vista Games | |||
| Missing icons in my vista games folder | Vista Games | |||
