Vista - CAPS LOCK INDICATOR - TURN OFF!!
Old 02-19-2008   #1 (permalink)
bumblebee
Everytime I select the caps lock key a little pop up indicator flashes on
telling me that i'm in either upper or lower case - its driving me mad. How
do i turn it off???
Old 02-19-2008   #2 (permalink)
Windows Vista x64 Ultimate
Re: CAPS LOCK INDICATOR - TURN OFF!!
Quote  Quote: Originally Posted by bumblebee View Post
do i turn it off???
I don't really know if it can be turned off. That "warning" message is there to remind you that the Caps Lock key has been turned on, and you are attempting to enter a password, for which the usual practice is either all lower-case characters, or a mix.
If you use a mixed-case password, then using the SHIFT key will invert the caps lock, so that upper become lower and vice versa.
This, obviously, will result in an incorrect password being entered.
Old 02-19-2008   #3 (permalink)
John Barnett MVP
Go to Control panel and click on the Keyboard icon. In the keyboard
properties window you should see a list of 'key names' and a description of
what they are assigned to. Locate the CAPS LOCK option and click he Edit
button. In the 'reassign' window remove the tick mark from the 'displays
CAPS LOCK status on screen' Now click Finish, followed by OK on the keyboard
properties window. The cap lock status should now not appear.
John Barnett MVP
Associate Expert
Windows - Shell/User
Web: http://xphelpandsupport.mvps.org
Web: http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"bumblebee" <bumblebee@xxxxxx> wrote in message
news:E37B556D-B1FD-46DF-900E-11BDE9AA22C5@xxxxxx
> How
> do i turn it off???
Old 02-19-2008   #4 (permalink)
bumblebee
thanks john, i tried this and can't even find the keyboard icon! - not sure i
have the same version as you. any further help?
> John Barnett MVP
> Associate Expert
> mail/post..
> > How
> > do i turn it off???
Old 02-19-2008   #5 (permalink)
bumblebee
no cordless mouse or keyboard used. It was fine until and engineer came and
installed my broadband and after he'd gone this annoying pop up was there!
"The poster fromerly known as 'The Poster" wrote:
Quote:
> > do i turn it off???
> Do you have cordless keyboard and mouse? The reason they do that with
> the cordless desktop setups/cordless keyboard is because then the
> keyboard will use less battery power if it does not need to power a caps
> lock/numlock led lights constantly. Look in the software that came with
> you cordless keyboard/mouse on how to turn it off.
> "Fair use is not merely a nice concept--it is a federal law based on
> free speech rights under the First Amendment and is a cornerstone of the
> creativity and innovation that is a hallmark of this country. Consumer
> rights in the digital age are not frivolous."
> - Maura Corbett
Old 02-20-2008   #6 (permalink)
DarkSentinel
> How
> do i turn it off???
Sounds like you are using the SetPoint software for Logitech Keyboards and
Mice. If this is the case, open SetPoint. Click the Tools tab, then click
the tab with Logitech eye. Under Status Indicators, uncheck the "Show status
setting changes" boxes. Click Apply, the OK, and that will stop the pop ups.
Sanity calms, but madness is more interesting.
http://www.lockergnome.com/darksentinel
Undo the munge to reply by email
Old 02-20-2008   #7 (permalink)
bumblebee
thanks, but i can't find any of the things you suggest!
> > How
> > do i turn it off???
Old 02-20-2008   #8 (permalink)
bumblebee
Thanks for your help John - it wasn't the broadband installation that did it,
it was the installer himself! i think i've found it now - he'd installed a
program called TODO - keyboard manager and i've managed to disable it and
have removed it from the start up menu.
thanks again everyone who suggested anything
Quote:
> Even though it is not a wireless keyboard does it have multimedia
> capability? In other words does it have buttons for opening your web
> browser, email, music and things like that? If it doesn't then there is no
> way, that I know of, to make the alteration you want. However, I cannot see
> how installing broadband would cause this problem to arise.
> Is there a keyboard picture (icon) in control panel? (see attached
> screenshot - marked with red arrow)Even a normal keyboard will have a
> corresponding icon in control panel, as too would the mouse. Obviously mine
> is a wireless keyboard, hence the instruction I gave you.
> John Barnett MVP
> Associate Expert
> Windows Desktop Experience
> mail/post..
> news:911A8B76-CB1C-424F-9C29-1A956CDCFA64@xxxxxx
> > sure i
> >> of
> >> keyboard
> >> John Barnett MVP
> >> Associate Expert
> >> for
> >> the
> >> mail/post..
> >> > on
> >> > How
> >> > do i turn it off???
Old 02-20-2008   #9 (permalink)
bumblebee
found the solution now, thanks again. The broadband installer had installed
a program called TODO - Keyboard Manager onto my machine and i've managed to
disable it and remove it from the start up menu
thanks again, all is good
> > > How
> > > do i turn it off???
Old 02-20-2008   #10 (permalink)
John Barnett MVP
I'm glad you managed to sort it out.
John Barnett MVP
Associate Expert
mail/post..
news:7EB29D00-28AC-427A-8F80-83E0889A8A14@xxxxxx
> it,
> a
>> no
>> see
>> mine
>> John Barnett MVP
>> Associate Expert
>> for
>> the
>> mail/post..
>> > sure i
>> >> description
>> >> of
>> >> Edit
>> >> 'displays
>> >> keyboard
>> >> John Barnett MVP
>> >> Associate Expert
>> >> any
>> >> accuracy,
>> >> liable
>> >> for
>> >> of
>> >> the
>> >> mail/post..
>> >> > flashes
>> >> > on
>> >> > mad.
>> >> > How
>> >> > do i turn it off???
Caps Lock Indicator, how to turn it off? General Discussion
Caps Lock Indicator General Discussion
HP On-Screen Caps/Num/Scroll lock Indicator Software
Notification area/ How to get rid of Caps Lock, Scroll Lock Vista General
caps lock indicator Vista General
