Vista - Safely removing devices and monitor blanking issue
Old 02-19-2008   #1 (permalink)
LostinUSBland
When I connect a USB device to my computer that has VISTA BUSINESS 32-bit
installed on it, the monitor screen will go black for approx. 5sec's and then
return. When I go to disconnect the drive via the SAFELY REMOVE HARDWARE, the
same thing happens again.
Can anyone tell me what I can do to resolve this issue.
This is a new install on a fresh harddrive with all recent updates from
microsoft's website. Have also tried the USB rollup driver with no luck.
Any help will be greatly appriciated...
Old 02-19-2008   #2 (permalink)
Mark L. Ferguson
Re: Safely removing devices and monitor blanking issue
No, there is not much you can do about losing display when Explorer
restarts. It's a bit like logging off and on.
Was this helpful? Then click the "Yes" Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"LostinUSBland" <LostinUSBland@xxxxxx> wrote in message
news:94EB746B-F101-4684-95F4-BA619D8C40CD@xxxxxx
> then
> the
Old 02-19-2008   #3 (permalink)
LostinUSBland
Thanks for your response, but I want to add that I had VISTA installed
previously on a MSI board with an AMD chip and did not have this issue. It
seems that I have only started having this issue since upgrading to an ASUS
board with and Intel chip..Not sure if there is any corrolation....
> interface.
> Mark L. Ferguson
> > then
> > the
Old 02-19-2008   #4 (permalink)
Michael Price
Make sure you have installed all the drivers directly from the hardware
provider sites. Sometimes the MS supplied drivers don't completely work. I
have that issue with a couple of the devices in my laptop. For example to
get full soundcard functionality I need the actual SigmaTel driver.
> then
> the
Old 02-19-2008   #5 (permalink)
LostinUSBland
Hi Michael,
Thanks for your response. I was just wondering are you saying that I have to
add a driver for any device that I plug into my pc? USB DRIVES and all??? It
just seems funny cause I have not had to ever do that before. I had VISTA
BUSINESS installed before and the only thing that I have changed is the
hardware.
I will give it a try and I will keep you posted...
Thank you...
> > then
> > the
Safely removing external HDD that system says is in use by another program Vista hardware & devices
SuperFetch, Log and $MFT keep me from safely removing portable HDD Vista hardware & devices
Windows Vista USB devices 'remove safely' Vista hardware & devices
Trouble Safely Removing USB Device Vista hardware & devices
USB - removing hardware safely? Vista General
