| | Re: Help Yes it is a USB network wireless adapter. Yes I check microsoft site and no go. How do they get x86 and x64 on the laptop I have. And yes it has both, I rechecked that. Is there a way to mod the driver. I did mod some drivers when Windows XP x64 came out and I did the beta testing to get hardware working. But it does not seem to work in Vista x64. Have any Ideals. Any help Tony "dzomlija" <dzomlija.352fqz@xxxxxx-mx.forums.net> wrote in message news:dzomlija.352fqz@xxxxxx-mx.forums.net... Quote: > > Auto Doctor;618880 Wrote: Quote: >> I need help with vista x64. >> I installed it today and my MN-510 does not have drivers for it. >> I have Vista Ultima x86 x64 on my HP laptop and the MN-510 works on it >> but >> when I installed Vista Ultima x64 on my main system it is not >> supported. >> I was thinking that if I installed Vista Ultima x64 it would also >> install >> x86 at the same time like on my laptop. >> How do I get it to do that. >> If need be I will reinstall it if someone tells me how I am to do it so >> x86 >> and x64 are installed. >> I purchased Vista x64 thinking it would install like the copy that came >> on >> my laptop. >> The laptop is HP8510 with an AMD 64 x2 >> My main system is a Intel Quad core x64 >> What gives. >> >> Tony > I not too sure what "MN-510" is (Printer, Scanner, TV Card, ???) > > A google search reveals this to be "Microsoft MN-510 Wireless USB > Adapter". Is this correct. Have you checked Microsofts Downloads for > drivers? > > And no, when you install Vista x64, you only get x64 (which runs x86 > software, but requires signed x64 drivers). > > > -- > dzomlija > > _____________________ > Peter Alexander Dzomlija > -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > you die, so shall I be Reborn...- > > -Download MP3 Media Properties Explorer: --http://www.phx.co.za- > > - ASUS A8N32-SLI-Deluxe > - AMD Athlon 64 Dual-Core 4800+ > - 4GB DDR400 > - 128MB ASUS nVidia 6600 > - Thermaltake Tai-Chi Chassis > - 1207GB Formatted Storage > - Vista Ultimate x64 > - CodeGear Delphi 2007See my rig at: > http://s229.photobucket.com/albums/e...zomlija/Venus/ |
| Windows Vista x64 Ultimate | Re: Help I need help with vista x64. I installed it today and my MN-510 does not have drivers for it. I have Vista Ultima x86 x64 on my HP laptop and the MN-510 works on it but when I installed Vista Ultima x64 on my main system it is not supported. I was thinking that if I installed Vista Ultima x64 it would also install x86 at the same time like on my laptop. How do I get it to do that. If need be I will reinstall it if someone tells me how I am to do it so x86 and x64 are installed. I purchased Vista x64 thinking it would install like the copy that came on my laptop. The laptop is HP8510 with an AMD 64 x2 My main system is a Intel Quad core x64 What gives. Tony A google search reveals this to be "Microsoft MN-510 Wireless USB Adapter". Is this correct. Have you checked Microsofts Downloads for drivers? And no, when you install Vista x64, you only get x64 (which runs x86 software, but requires signed x64 drivers). |
| Windows Vista x64 Ultimate | Re: Help Yes it is a USB network wireless adapter. Yes I check microsoft site and no go. How do they get x86 and x64 on the laptop I have. And yes it has both, I rechecked that. Is there a way to mod the driver. I did mod some drivers when Windows XP x64 came out and I did the beta testing to get hardware working. But it does not seem to work in Vista x64. Have any Ideals. Any help Tony If the driver isn't specifically written for Vista - it won't work. You can't use 32-Bit drivers on a 64-Bit system. You can't use 64-Bit drivers on a 32-Bit system. When you right-click on "Computer" and selct "Properties", what is your system type listed as? If it states "64-bit Operating System", then you need to use 64-Bit drivers. If it states "32-Bit Operating System", then you need to use 32-Bit drivers. If you are using Vista x64, then I think your confusion about having both x86 AND x64 stems from the fact that you can run both x86 (32-Bit) and x64 software. But you can only use digitally signed and certified x64 drivers. If you are using Vista x86 (32-Bit), then you can only run x86 (32-Bit) software, and can only install x86 (32-Bit) drivers. The only other way to get both Vista x86 and Vista x64 on the same computer would be to install using a dual-boot setup. But even then, you can only run one version at a time. If you cannot get specific x64 drivers for your wireless, then you are out of luck, and need to purchase a new wireless usb dongle that provides x64 support for Vista. |
| | Help I need help with vista x64. I installed it today and my MN-510 does not have drivers for it. I have Vista Ultima x86 x64 on my HP laptop and the MN-510 works on it but when I installed Vista Ultima x64 on my main system it is not supported. I was thinking that if I installed Vista Ultima x64 it would also install x86 at the same time like on my laptop. How do I get it to do that. If need be I will reinstall it if someone tells me how I am to do it so x86 and x64 are installed. I purchased Vista x64 thinking it would install like the copy that came on my laptop. The laptop is HP8510 with an AMD 64 x2 My main system is a Intel Quad core x64 What gives. Tony |
