1.    19 Feb 2008 #1
    wolverinegod Guest
    Adjusting Vista's Lock settings
    I, as I assume many others, am extremely frustrated with my computer
    locking after a very short period of sitting idle. I have looked
    everywhere for a place to adjust the amount of time i have before
    windows locks. Does anyone know how to do this? I'm running Ultimate.
  2.    20 Feb 2008 #2
    Don Varnau Guest
    Re: Adjusting Vista's Lock settings
    Change your Screensaver settings.
    Right-click the desktop> Personalize> Screensaver. Change the time before
    the screensaver comes on and/or uncheck "On resume, display logon screen."
    Don
    [MS MVP- IE]
    "wolverinegod" <wolverinegod@xxxxxx> wrote in message
    news:333ec73e-8937-4b48-8671-58cb8ed3a9ff@xxxxxx
  3.    20 Feb 2008 #3
    wolverinegod Guest
    On Feb 20, 5:15 am, "Don Varnau" <don_04[at]varnau[dot]org> wrote:
    > Hi,
    > Hope this helps,
    > Don
    > [MS MVP- IE]
    > "wolverinegod" <wolverine...@xxxxxx> wrote in message
    My screen saver runs fine, the problem is the computer will lock
    eventually - i don't want to disable it, just adjust how long until it
    locks.
  4.    21 Feb 2008 #4
    Don Varnau Guest
    > > Hi,
    before
    screen."
    news:13dd3635-a2d2-45e9-858d-e40f351dcab2@xxxxxx
    > locks.
    Assuming that you *do* want the computer to lock automatically...
    Go to Control Panel> Power Options and experiment with sleep settings. You
    can set sleep to occur sometime after the screensaver comes on and require a
    password on wakeup.
    Then, go to screensaver settings and uncheck "On resume, display logon
    screen."
    I don't know of another method, unless there's a third-party program
    available.
    Don
    [MS MVP- IE]
  5.    21 Feb 2008 #5
    wolverinegod Guest
    > > > Hi,
    > before
    > screen."
    > > locks.
    > Hi,
    > password on wakeup.
    > screen."
    > available.
    > Don
    > [MS MVP- IE]
    Thanks Don, that sounds like my best bet.... i'm surprised there isn't
    a setting for locking the computer.... but this is a good start.
Unlock Scroll lock / Num lock keys on HP DV 6 Thousand
I have a Vista home premium Thirty Two bit on a HP DV Six Thousand laptop. A few days ago, I have no idea how, but the scroll lock has been turned...
General Discussion
Notification area/ How to get rid of Caps Lock, Scroll Lock
Can some tell me how to get rid of the Caps Lock, Scroll Lock, & Numbers Lock off of the Notification area?
Vista General
CAPS lock / SHIFT lock difficulty
Can anyone give me instructions on how to control these to keys? Somewhere along the line I must have pressed some wrong key combinations and now...
Vista General
Vista Crashes when Changing/Adjusting Sound
Hi, I've been having this problem for about a week with Windows Vista 32bit where the computer freezes if I try to adjust the sound. It happens...
Vista General
Adjusting volume settings in Windows Live Messenger
Everytime I am connected to Windows Messenger Live, and one of my contacts gets online or I get an incoming message, I hear the alert sound. Which...
Vista mail
adjusting text readability settings
I am using Vista HP, I have my monitor res set at 1280 x960 on a 19inch Samsung Syncmaster 940N monitor and using segoe UI font at size 9....
Vista General
Adjusting the live preview size on Vista Aero (when Alt-Tab switching)
This has been asked before but with no results: anybody knows how to change the size of live preview windows when switching applications using...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
