Vista - A2DP Bluetooth Stereo Vista Problem
Old 02-22-2008   #1 (permalink)
Tommy
Hi.
Can someone help me out by telling me how to get a Bluetooth Stereo Headset
working on Vista?
I've got the latest Broadcom update available
http://www.broadcom.com/products/bluetooth_update.php but stil can't get the
stereo headset to work properly which is no problem at all on XP.
It's apparently a common Vista problem to get the A2DP support working.
Hope that someone here got a solution to this.
My notebook is an Acer Aspire 5920 with Vista Home Premium using the Widcomm
software 6.0.1.6200.
Tried it on my other notebook with Vista Ultimate but the same thing, the
headset is connected but the sound (Music) starts playing for a second than
stops 3-4 sec comes back again and dissapears.
Thanks in advance,
Tommy
Old 02-22-2008   #2 (permalink)
Mark L. Ferguson
Re: A2DP Bluetooth Stereo Vista Problem
Don't know if it will help, but it wouldn't hurt to look over the fix that
worked in XP.
Go to HKLM\SYSTEM\CurrentControlSet\Control\Class\. Delete the following
key: {e0cbf06c-cd8b-4647-bb8a-263b43f0f974}. Open Device Manager. (run
devmgmt.msc) Remove the Bluetooth radio listed here. Click Action, click
Scan for hardware changes. This should re-enumerate the Bluetooth adapter.
Was this helpful? Then click the "Yes" Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"Tommy" <Tommy@xxxxxx> wrote in message
news:61437734-ACD4-4C5C-9789-3ACD0A65C04F@xxxxxx
Quote:
> Hi.
> Headset
> working on Vista?
> the
> Widcomm
> than
> Thanks in advance,
> Tommy
Old 05-03-2008   #3 (permalink)
Vista Home Premium 32bit
Try using Bluesoleil at this link BlueSoleil, 22 million users’ choice for Bluetooth software, Bluetooth driver
hope this solves ur problm. The guide in the site is pretty good.
jnraj63
jnraj63 is online now Add to jnraj63's Reputation Report Post Edit/Delete Message
Old 05-03-2008   #4 (permalink)
Tommy
........I tried Bluesoleil but it didn't work.
A problem that many people are having with it occured.
Bluesoleil didn't recognized my build in Bluetooth.
I contacted Bluesoleil support but they couldn't help as well.......
> jnraj63
> Edit/Delete Message
> jnraj63
A2DP not available for Vista x64? Drivers
stereo mix problem Sound & Audio
Motorola S9 bluetooth headset A2DP connection problems Vista General
AD2P Bluetooth Stereo on Vista Sound & Audio
Bluetooth Audio Streaming (A2DP) Vista hardware & devices
